Warming up your engine
Old May 3, 2012 | 02:44 PM
TLS_Addict's Avatar
TLS_Addict
If you use Burger King oil in it you can run it WOT within 5 seconds of starting it. True story.
Old May 3, 2012 | 03:57 PM
06 C6 vert's Avatar
06 C6 vert
I live on a high speed country road that I have to back out onto with my DD in the vette.
During rush hour I will warm vette for 5 min in case I need a very quick launch once I back out.
Old May 3, 2012 | 04:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I get in and go slowly until at operating temps of atleast 150 on oil
Old May 3, 2012 | 04:13 PM
speedlink's Avatar
speedlink
Originally Posted by tampatopless
How long do you let it run? Do you get right in and go? A few minutes? Until temp needle starts to move? Until temp needle is above 150?
I was wondering if it's different with today's engines? I remember back in the day, my parents used to let the car get good and warm and you were taught never to gun a cold engine.
I just let it idle until the belt is in place, then go.
Just drive gently for the first few miles, until the temps go up. It's never good for an engine to sit and idle to warm up. Lot's of ware problems etc.
Old May 3, 2012 | 04:38 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
When I was a little kid back in the '50's, I remember my dad would always be in the car first to "let it warm up." It wasn't a matter of heating up the interior, we lived in California. He'd sit there with the motor running listening to the radio while waiting for us to finish getting ready and get into the car.
For a long time I thought he did that just to get away and be by himself for a few minutes. Now I know that he was a car-guy and was doing what was best for the car. They sure lasted long enough...
Old May 3, 2012 | 04:58 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Start and go but keep to lo load until at least the coolant is warmed up. With the early Z06 oil cooler, it takes a very long time to warm up the oil in the fall/winter/spring so I still do hit the throttle with the oil below 150* but I try to keep it to a minimum.
Old May 3, 2012 | 05:05 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I live in Arizona so for much of the year the car is already warmed-up before I even start it.
No real warm-up period is necessary...I pretty much start it and drive. That said I don't go WOT until the engine has warmed-up.
Old May 3, 2012 | 05:13 PM
truth.b's Avatar
truth.b
Originally Posted by Licit
There are plenty that get in, start it up and drive off like they stole it. I don't do it but know plenty that do and I don't hear them having to get engine repairs done. What you do at startup and below normal operating temps is probably more of a problem in the long term, since most vettes are "high mileage" at 30000 miles who knows what a lot of engines are/will be like at over 60000 miles.
Ummm ... I'm no expert but when did "most vettes" start being considered high mileage at 30,000 miles ? And aren't there plenty of 200,000 mile LS2 & LS3 engines out there on the road today ...
Old May 3, 2012 | 05:26 PM
brooklync5's Avatar
brooklync5
Jump in and go for me. Just Take it easy for the first few minutes then the fun begins.
Old May 3, 2012 | 05:40 PM
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Originally Posted by vintagez
Let it idle while I do up my belt and drive slowly away short shifting till it warms up
Old May 3, 2012 | 05:44 PM
SanDiegoBert's Avatar
SanDiegoBert
"Today's engines" are mechanically identical: Bearings lubricated by oil under pressure. Common wisdom nowadays is to start the car, wait until the idle stabilizes, then drive off. Keep the revs under 2500 oe so until the coolant and oil warm up.
Old May 3, 2012 | 07:14 PM
wase13's Avatar
wase13
You only need to warm up old carb engines, no need for warming up in modern fuel injected engines.....
Old May 3, 2012 | 08:32 PM
  #33
Don-Vette's Avatar
Don-Vette
1. Get in
2. Sit down
3. Shut up
4. Hold on
Old May 3, 2012 | 08:43 PM
  #34
Gary '09 C6's Avatar
Gary '09 C6
I just take it easy until both coolant and oil have reached normal operating temperatures.
Then what Don-Vette says above...!
Old May 3, 2012 | 10:36 PM
  #35
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Most engine wear occurs when the engine is cold because the various components are at different temps and expand at different rates. The best thing you can do is get it up to operating temp ASAP. Idling prolongs that. The best thing to do is what most here are saying. Start it up. Let it idle for 30 seconds or so until the rpm drops. Then drive it easy, keep it below 3000 rpm until oil temp is at leat 150. I usually wait until it's 180.
Old May 3, 2012 | 11:03 PM
  #36
cartwheel's Avatar
cartwheel
I just get in it and go about 30 seconds later but try keep the rpms below 3000 till oil temp reaches 175 degrees.
Old May 3, 2012 | 11:13 PM
  #37
Just Buy It's Avatar
Just Buy It
Originally Posted by Chemdawg99
IMHO you are right about everything except the below zero advice. If its below zero don't drive the car in any conditions. Stay inside and drink. Below zero is not a good place to be.
To Warming up your engine
Old May 3, 2012 | 11:20 PM
  #38
Dendk's Avatar
Dendk
As soon as the good morning message clears on the DIC I go...
Old May 4, 2012 | 08:55 AM
  #39
vintagez's Avatar
vintagez
Anyone else get a lean surge between 1000 and 2000 rpm while say cruising out of a parking lot with a cold start on the engine? My 2009 manual coupe exhibits this symptom for about 3-4 minutes after a cold start with only about 5000 miles (8000 kms), once speed is up everything is fine.
Old May 4, 2012 | 09:22 AM
  #40
BlueOx's Avatar
BlueOx
Before what?
Normal driving? No real need.
Hammering it hard? Probably at least 5-10 minutes of normal driving. I'd want it warmer than 170 before hitting it really hard.
