Help removing map lights
Old Sep 25, 2012 | 11:17 AM
RO55's Avatar
RO55
Originally Posted by LS WON
I found the hood light to be most difficult and the glove box light the easiest.
How does the hood light one come out? I looked at it and do you squeeze the top & bottom of the lens? Thanks!
Old Sep 25, 2012 | 11:25 AM
LS WON's Avatar
LS WON
With hood light you have to be careful not to blow the fuse. If you do the fuse is located in the passenger footwell. The hood LED light is a flat light that shines to one side.
Old Sep 25, 2012 | 11:30 AM
RO55's Avatar
RO55
Ok then the light bulb is like the trunk ones. But how did you get the lens cover off or does the entire assembly pull free from hood liner?
Old Sep 25, 2012 | 11:35 AM
N2TU's Avatar
N2TU
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
Originally Posted by szaro1
may sound silly but i used a piece of floss to wrap around the top of the bulb and then pulled gently and it came rite out... hopefully this helps...
Same here...worked great!
Old Sep 25, 2012 | 11:40 AM
LS WON's Avatar
LS WON
That cover comes off easily just push a little and the bulb you can see how it comes out.
Old Sep 25, 2012 | 11:42 AM
RO55's Avatar
RO55
Thanks!
Old Sep 25, 2012 | 06:14 PM
corvetteattic's Avatar
corvetteattic
7th Gear
Default Help on C6 Bulbs
I just wanted to thank all the people out there who posted hints for C6 bulb replacement. I found a lot of good things through the forum. The rear side markers are accessed through the outside taillights. The glove box light is accessed by removing the panel around the glovebox, lowering the glovebox, and then removing the assembly where the light is. The backup lights are reached by going over the diffuser and just pulling them out. The footwell light I found were easily obtained by removing the panel they are in, then removing the light housing and then snapping them back into the housing. The map/mirror lights were , for me, best obtained by using a paper clip to remove cover, then using a small zip tie to get out the bulbs. These were all sugestions from others, I just kind of lumped them together since I just did all my light changes today on my C6 Grand Sport. Thanks again to all the forum posts to help us out.
Old Sep 25, 2012 | 07:36 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by corvetteattic
I am a first time user on this site and finally decided to sign up with all the great help out there. I bought LED upgrade lights for my 2013 Grand Sport, but realluy didnt know how to put them all in and thanks to this great site and the great Corvette community I am almost done.
Thread got a little off-topic when it was revived after the 45-day limit.
http://forums.corvetteforum.com/foru...s-or-more.html
Usually better to start a new one.
