Help removing map lights
Old May 19, 2012 | 12:39 AM
jwaldro2's Avatar
jwaldro2
Default Help removing map lights
Got the interior led lights from corvette mods. I cannot get the map lights out! Any help. I've tried taping them and using needle nose but I can't seem to get it
Old May 19, 2012 | 12:51 AM
LS WON's Avatar
LS WON
I did the swap out successfully and I pulled the bulbs out very carefully using a needle nose plyer.
Old May 19, 2012 | 12:52 AM
jwaldro2's Avatar
jwaldro2
With nothing on them? I'm afriaid I'll shatter them lol
Old May 19, 2012 | 12:53 AM
szaro1's Avatar
szaro1
may sound silly but i used a piece of floss to wrap around the top of the bulb and then pulled gently and it came rite out... hopefully this helps...
Old May 19, 2012 | 12:55 AM
jsucraig's Avatar
jsucraig
This is how I did it.
Old May 19, 2012 | 01:01 AM
LS WON's Avatar
LS WON
very very carefully.
Old May 19, 2012 | 01:29 AM
jwaldro2's Avatar
jwaldro2
I gave up for tonight lol I did all the ones except map and footwell I'll try the dental floss tomorrow
Old May 19, 2012 | 01:34 AM
LS WON's Avatar
LS WON
Did you do the engine light under hood if you have one and the glove box too?
Old May 19, 2012 | 04:26 AM
AKc62007's Avatar
AKc62007
Default string is the trick
you have to use string tie a knot in the string then carefully wrap it around the bulb and tighten it up. Then pull down and it will pop out. It will take a few tries but thats how its done.
Alex
Old May 19, 2012 | 08:38 AM
Icetoad's Avatar
Icetoad
i used a video on youtube that showed how to make a slipknot. Once i mastered it with the string i had(dental floss works too), i was then able to pull my map lights out. The good news is that the LED lights go in easily and they come out easily(assuming you want to change them again).
Old May 19, 2012 | 11:28 AM
jwaldro2's Avatar
jwaldro2
I'll try all the above methods and yes I did the engine light and I am going to do the glove box
Old May 19, 2012 | 11:46 AM
JCtx's Avatar
JCtx
I used needle-nose pliers with duct tape around the tips, then turned inside out a couple of turns, so sticky side is exposed. They came right out. And yes, I used a rag under the mirror in case I broke a bulb. Good luck.
Old May 19, 2012 | 11:56 AM
scootertrash19's Avatar
scootertrash19
I used a small piece of rubber fuel line, push over the end of the bulb, then pull straight out.
Old May 19, 2012 | 12:05 PM
jwaldro2's Avatar
jwaldro2
Old May 19, 2012 | 12:16 PM
grady's Avatar
grady
anyone with a video on how to do this?
Old May 19, 2012 | 01:26 PM
jwaldro2's Avatar
jwaldro2
I should have videoed. I took a piece of string (size of yarn but stronger) tied a slip knot. Here is the trick get it tight on there where it will not slide down. Before you pull the long end of your string to completely tighten take some tweezers and push the knot and the circular part of string surrounding the bulb. Push it as far in as you can and hold the knot and string with the tweezers pull down on the long end of the string and kind of pull out, they both came right out for me they were def snug. Main thing is be patient lol. I found this order easiest to hard. Rear hatch lights, underhood light, tag lights, reverse lights, footwell lights and the hardest map lights.
Old May 19, 2012 | 01:54 PM
jwaldro2's Avatar
jwaldro2
Also that slip knot helped me remove the plastic screw tabs in the footwell. I loosened them then put the circle around the head of the screw tab yanked on it a few good times and they came right out. Also used the slip knot on the incandescent bulb bc it's so hot to touch I put in the circle tightend wiggled the string a few times and it popped right out. Hope this helps anyone struggling
To Help removing map lights
Old May 19, 2012 | 07:38 PM
LS WON's Avatar
LS WON
I found the hood light to be most difficult and the glove box light the easiest.
Old Sep 25, 2012 | 10:14 AM
corvetteattic's Avatar
corvetteattic
7th Gear
Default Corvette C6 Bulbs
I am a first time user on this site and finally decided to sign up with all the great help out there. I bought LED upgrade lights for my 2013 Grand Sport, but realluy didnt know how to put them all in and thanks to this great site and the great Corvette community I am almost done.
Old Sep 25, 2012 | 10:56 AM
LS WON's Avatar
LS WON
It's the same as if you had to replace map lights if they had burnt out. You can use a piece of dental floss with a slip knot to grab onto bulb and gently pull on it. Depends on how tight those bulbs are in there. I remember just pulling them out with needle nose pliers but this can damage surrounding area if you aren't super careful.
