LS3 Balancer Issue -- Clutch Issues??
Old Jun 4, 2012 | 06:01 PM
CDaniel525's Avatar
CDaniel525
Default LS3 Balancer Issue -- Clutch Issues??
I was with a friend looking at a 08 C6 Coupe LS3 obviously, MN6... Artic White, 43k miles, Chrome Gumbys, otherwise stock! Asking price of $32.5k
Car looked absolutely stunning! But had a few issues...
The belt had a squeak and I looked under the hood and appeared the belt was was wobbling side to side down by the balancer, headed up towards the passenger side of the car... It squeaked louder as you raised the RPM...
Any known issues with this?? First thing that came to mind was the balancer recall/tsb thats common on the LS2s... But didnt think there were any problems with the LS3?? I dont think it was just a worn out belt...
ALSO, when you let out the clutch on the car, it sounded like something clunking in the bellhousing area. Like it was trying to engage, even though its in neutral. It was definitely louder the quicker you let it out.... It also seemed like it was only doing it while the car was running, and I dont recall if it was or was not while running. The clutch fluid was a little bit low and extremely dirty!
Is this just a clutch on its way out, or is there something malfunctioning.
Thanks a lot guys.... Chris
Old Jun 4, 2012 | 06:06 PM
LMBC6Brian2's Avatar
LMBC6Brian2
My 07 LS2 came from the factory with the balancer wobble. Added a blower to the car and had the belt chirp until the day I sold it. I tried 3 different brand belts and replaced all the blower kit pulleys. No dice. I would walk away from that car.
Old Jun 4, 2012 | 06:28 PM
brooklync5's Avatar
brooklync5
The Harmonic balancer is a known corvette issue dating back to th c5 it's an extensive job but if he far has power train warranty it's covered anyway. As for the clutch sounds a bit strange it might just be on the way out. All should be considered in negotiation of the final price. If these are the only 2 issues I wouldn't run away from it but negotiate for sure
Old Jun 4, 2012 | 06:41 PM
JSB LS3's Avatar
JSB LS3
The clutch thing sounds a bit like a throwout bearing problem.
Old Jun 4, 2012 | 08:49 PM
CDaniel525's Avatar
CDaniel525
Hmm, from what I could tell on the Carfax, the in service date of the car was April 2008... So it should still be under the powertrain warranty, even though the dealer kept saying it wasnt cause the CarFax said it wasnt. I mentioned checking the GMVIS and warranty status through service but they seemed to not know what I was talking about
Hmm, is this something covered under the powertrain?? Forgot to mention above the clutch fluid was a little bit low, and extremely dirty!
As of now, the dealer brought the car over to the service center to have them check those issues out. I wonder if they'd repair both issues and still be negotiable?
Old Jun 4, 2012 | 10:27 PM
MR_JLR's Avatar
MR_JLR
Not sure about the balancer for LS3, but I would say it's possible to all C6's.
As for the clutch, I think I made a thread last year about the same noise, you let it out quickly and you get a nice "pop", let it out slowly, no noise. And it only happened when the car was running, noise could not be reproduced with vehicle off. I think I seen a thread on here that also stated they were told it was normal. I was also told by a corvette mechanic that it was normal but who knows. I've owned a lot of cars in my 30 years of life and have never had more strange noises from a car than the Vette. All is forgotten with targa top removed and/or windows down.
To LS3 Balancer Issue -- Clutch Issues??
