Rear hatch pull down issue.
Old Jul 1, 2012 | 12:53 PM
djbrun's Avatar
djbrun
Default Rear hatch pull down issue.
This started just a few weeks ago, just to give you a run down on how often it is used. My car has 16K on the clock so I haven't used the hatch all that much.
Here's my issue, the spring loaded lever has worn so that the hatch loop will not glide over anymore. This is what the hatch rests on before you push it down to activate the pull down function.
Right now I pretty much have to shut it hard just to get it to shut. I had to lube it quite a bit just to get it to even do that.
I am going to remove my lever and have my machine shop make me a delrin piece to help prevent this in the future.
I am just wondering if I am just a fluke case, or have any of you run into this?
Thanks,
DJ
Old Jul 1, 2012 | 01:39 PM
Gman in NC's Avatar
Gman in NC
Not sure exactly what your problem is but I haven't had a problem with mine in seven years. I lay the hatch down gently until it stops then push to activate the pull down motor. I'd say you have an isolated issue there. Don't really recall seeing much about the hatch on here except guy that want to drop the hatch to shut it. I don't like to do it that way.
Old Jul 1, 2012 | 01:48 PM
djbrun's Avatar
djbrun
My explaination is probably not all that clear. Basically my lever developed a step stopping my hatch from working in the manner that you just described. The hatch loop slides down the spring arm until it can be pulled down. The step that has developed on my arm creates a hard stop, it will just not go by this step, even if you really push down hard on it. So, you need to shut it hard (Which you do not want to do.) to get it to shut.
I haven't seen any posts about this, so I am thinking I just got unlucky. It will be a somewhat easy fix, just surprised how easy mine failed.
DJ
Old Jul 1, 2012 | 02:51 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I've never had issues with my 2005. I lower the hatch (until it's resting on the latch) and then I push-down firmly to engage the pull-down mechanism. I don't ever try to slam it shut.
Old Jul 1, 2012 | 03:01 PM
JCtx's Avatar
JCtx
I've only read that the spring gets weak, and your fingers can't get under the hatch anymore. But some vendors sell an assist spring for that. I haven't scrutinized the latch mechanism to know what you're talking about. A pic would have been nice. Anyway, did you buy your car used? Maybe previous owner used to slam the hatch closed (I've seen many Corvette owners do that), not knowing it pulls itself closed. As a comment, if you push down steadily on the hatch the pull-down motor doesn't engage, at least on my car. I have to give it a quick push and it then engages. Will scrutinize it one of these days. Good luck.
Old Jul 1, 2012 | 03:04 PM
LS WON's Avatar
LS WON
On my 2005 I just make sure one of the doors is open and the hatch drops down easily and locks.
Old Jul 1, 2012 | 03:10 PM
kp's Avatar
kp
Both my '07 and '08 had the latches replaced for the 'pull down' not working after a while, had to slam them pretty hard. Seem to remember that being a fairly common issue back then.
Old Jul 1, 2012 | 03:12 PM
Larry/car's Avatar
Larry/car
I just assist gravity a little when I close my hatch, not slammed, closed firmly. Sometimes the closing feature activates, many times gravity prevents this from happening as the latch locks prior too. No problems in six years.
Old Jul 1, 2012 | 03:13 PM
Mad*Max's Avatar
Mad*Max
this
Old Jul 1, 2012 | 03:16 PM
LS WON's Avatar
LS WON
My hatch door also has a latch to grab a hold onto whereas I heard the new ones don't have anything.
Old Jul 1, 2012 | 03:23 PM
djbrun's Avatar
djbrun
I will have to take a picture to show you. Until just a few weeks ago it worked fine. Slowly lower the hatch until it rests on the spring lever, and then just push on the glass just a little and the motor would take care of the rest.
The whole purpose of this is to not slam the hatch and possibly blow out the rear window. Even though I have to shut it hard just to get it to work, the motor still slows it down, but I still need to fix it this week.
If I get done my yard work in time today I will snap a pic or two.
DJ
Old Jul 2, 2012 | 11:02 AM
pcguy2u's Avatar
pcguy2u
The 05 we had never had a problem with the hatch, closed doors or not. But the 09 needs to come to rest on the stop and then needs to be pressed on firmly. Trying to close it by dropping it just a bit from above, even with another door open, causes it to close half way and then you need to opening it and start over.
The dealer was clueless and suggested this was normal.
They must have changed the mechanism along the way - let's here it for progress....
Old Jul 2, 2012 | 12:46 PM
dcarter0001's Avatar
dcarter0001
The hatch on my 05 has been opened and closed thousands of times. I had a problem with the rear touch pad switch, I removed and cleaned to correct it. The pull down mechanism on the hatch is one of the few things that have performed flawlessly over the years.
Old Jul 2, 2012 | 01:10 PM
bud miller's Avatar
bud miller
when all else fails...a little WD-40 may help.
To Rear hatch pull down issue.
