Hard reverse shift
Old Jul 10, 2012 | 12:03 PM
dblais's Avatar
dblais
Default Hard reverse shift
Advise for my 05 Coupe, M6. I have a MGW shifter. This was installed 3 yrs ago. Last week after driving about 25 miles I could not shft into reverse. I finally used 2 hands and virtually forced it into Reverse. The next day after the car cooled down I started the car up and shifted to reverse multiple times. I suspect the shifter may have issues when the car is hot. It is a very stiff shifter to begin with but I do know it wasnt' me. Any other feedback would be appreciated. I intend to call MGW.
Old Jul 10, 2012 | 12:24 PM
heli-vette's Avatar
heli-vette
The ball end could be worn . I try to go to 5th gear and let the clutch out a bit to roll the gears .. A new MGW shifter is a HUGE improvement to reverse shifter , maybe some new MGW parts and lube will fix it .
Old Jul 14, 2012 | 09:11 AM
dblais's Avatar
dblais
Default Follow up from MGW
I called MGW about my problem. George explained the diagnostic procedure. This was a big help. Basically the transmission has a feature to prevent accidental shifting to R while the car is moving. I tried the shifter with and without power in the garage. If the fuse is blown the shifter is very difficult to ship into R. I cut to the chase and checked my fuse box and sure enough the Trans fuse was blown. I will advise when the car is driven and if I blow another fuse. Thanks to MGW
Old Jul 23, 2012 | 07:56 PM
dblais's Avatar
dblais
Default reverse shift progress
I replaced the #10 fuse for the trans. The fuse was blown. I expected the hard shift to reverse to be eliminated. No Go. The problem still exists. My next move is to replace the solenoid. Any feed back would be appreciated.
To Hard reverse shift
