Anyone able to answer the question about if this can be done by Chevy Dealership and if they will use the specs that you give them?
My dealer did the alignment with only one comment basically saying they weren't responsible for tire wear.
I immediately noticed a difference in the feel - it was like having power steering on steroids. Something I'll have to get use to. For me the jury is still out as to whether I like it. Stay tuned.
had the 12 aligned today using the PFADT specs for street. could tell the difference right away, car more relaxing to drive, the car does not chase the roadway. checked the handling coming off the highway on the way home, took the exit at a rather high speed and she stuck to the ground like she was glued to it...now to wait and see how the tire wear will be affected...
Did the same today to my 2013 GS. Noticeable difference. Ditto to what you said. Also first oil change and replaced drain plugs with magnetics. They also replaced a rear suspension support crossmember the tech said was making a clunking sound. I didn't notice it, but it was all under warranty, so it's all good...still loving the Corvette!!!!
OK, after a couple days of driving I like the new feel. Also something strange, I know its just a feel but the cars seems lighter. Weird.
yes, the exact same feel when i had mine done. its like i am NOT trying to plow a furrow in the road, down the center of the car... then again, i aint going 160+mph to see how really light it would feel then!!
Needed to put some miles on it before I could comment. It is a very different feel. Much better. Seems more stable or "planted" now.
Went for a 25 mile drive today with varied RPMs and road types and it did feel exactly how you described. Much better...my only question is why can't they get it right from the factory?
It's possible they did, but the C6 suspension settles noticably after a thousand miles or so. That can throw off even a perfect factory alignment, and i don't they are all that perfect out the door.
Curious about the rear suspension crossmember they replaced?
Bert
Roll Tide!
I was too. I didn't have time to really get into it with the tech, but he said it was a common problem, so they just went ahead and fixed it. I didn't notice the clunking sound he spoke of. He said he noticed it when he went for the alignment road test...
Are the Pfadt specs model specific or applicable to all the C6 line? Does anyone have experience with both the standard factory setting and the Pfadt settings for the new 2013 RPO427 Vert?
My coupe has always pulled slightly to the right since it was new. It was never bad enough for me to worry a whole lot about it, but does anyone know if the dealer can realign it under warranty? The car has just over 5k miles now.
