New Alignment
Old Aug 7, 2012 | 11:37 PM
MidYearRoadster's Avatar
MidYearRoadster
Default New Alignment
had the 12 aligned today using the PFADT specs for street. could tell the difference right away, car more relaxing to drive, the car does not chase the roadway. checked the handling coming off the highway on the way home, took the exit at a rather high speed and she stuck to the ground like she was glued to it...now to wait and see how the tire wear will be affected...
Old Aug 7, 2012 | 11:57 PM
ChevyDave's Avatar
ChevyDave
i too did the same today on our 2011 GS. i had my dealership realign about 1k ago and it still pulled slightly to the right.
after todays PFADT performance street, the pull went away and it felt much more comfortable with road swags/dips.
i think my dad used to say.. 'she rabbit tracks'.
Old Aug 8, 2012 | 12:01 AM
JimmyLee's Avatar
JimmyLee
Had it done last week at 8k to reduce tire wear. Noticed a significant reduction in tramlining (chasing the road).
Old Aug 8, 2012 | 02:48 PM
Bedouin's Avatar
Bedouin
I lowered mine on the stock ride height bolts & then had the aligment checked. It went from -1* front camber/ -.8* rear camber, to -1.2* & -1 respectively...I was pleasantly surpised by the improved cornering ability.
Old Aug 8, 2012 | 10:01 PM
Gary '09 C6's Avatar
Gary '09 C6
had mine identically done a few months back..remarkable difference.
Old Aug 8, 2012 | 10:05 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Gonna do mine to the Pfadt street specs on Friday...after your experience, I can't wait....totally psyched...will report afterwards on my experiences with it..
Old Aug 10, 2012 | 08:30 AM
Deftly's Avatar
Deftly
Is your GS stock or have you changed the suspension? I have looked and can't find the specs. What are they? Did you have it done by a dealer and did they give you any grief about the alignment?
Old Aug 10, 2012 | 08:41 AM
Cypher's Avatar
Cypher
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
Had my ’12 Z set to PFADT “Performance Street” specs a couple months ago and the car definitely feels less “twitchy” on the road now.
Old Aug 10, 2012 | 08:47 AM
Deftly's Avatar
Deftly
Old Aug 10, 2012 | 09:49 AM
Nyvetteguy007
Had the Vette done early this morning to the Pfadt Street Specs at Little Bear in Buchanan NY, they were great and set up the car as per the Pfadt specs no problem....drove the car around for a bit afterwards and so far the car feels FANTASTIC!!
Pic of the car on the rack
Old Aug 10, 2012 | 11:27 AM
ladder13's Avatar
ladder13
How much they get for the alignment, thanks?
Old Aug 10, 2012 | 11:30 AM
Nyvetteguy007
$128.00
Well worth it in my eyes...they test drove before and after, very professional...Wheel alignments are their main specialty...
Old Aug 10, 2012 | 03:09 PM
ladder13's Avatar
ladder13
$128.00
Thanks for the info, I may try them soon.
Old Aug 10, 2012 | 04:30 PM
Aviator's Avatar
Aviator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Had my car aligned to the Pfadt Street Performance specs today as well. Sho said if I want to maixmize tire life, I should ignore GM's tire pressure setting of 30 PSI cold and bump it up to 35 PSI or even 40 PSI. They said 30 PSI will give you a more comfortable ride but chews up the tires much more quickly than if you set the pressure higher.
Anyone running their tire pressure higher than factory specs? Impact on tread life?
Old Aug 10, 2012 | 04:42 PM
Nyvetteguy007
I have heard the same...I'm gonna try running 32-35 see how that works out....
Old Aug 10, 2012 | 08:12 PM
Spark 2's Avatar
Spark 2
St. Jude Donor '07-'08-'09
Can someone please post a PFADT spec sheet that I can read or print.
I've tried several times and can not read the original sheet,
When I try to print it out at 200% its a blur ?
Thanks for your help!
Old Aug 10, 2012 | 08:30 PM
Nyvetteguy007
This should work, if not PM me and I can email it to you.
To New Alignment
Old Aug 10, 2012 | 08:35 PM
ladder13's Avatar
ladder13
So we're using the first set of specs, Performance Street, correct? Did you get a before and after printout?
Old Aug 10, 2012 | 09:14 PM
Nyvetteguy007
Yes first set of specs.
I watched them input everything....was on a conference call when they were done and forgot to ask for the printout!
Old Aug 10, 2012 | 09:26 PM
jcarl's Avatar
jcarl
Anyone able to answer the question about if this can be done by Chevy Dealership and if they will use the specs that you give them?
