TPMS question/issue
Bill
I have one you can have from my 06. PM me your address and I will mail it to you.
All 2005-2009 Vettes built for delivery in the U.S. have OE sensors like this:
You can see the number 25758220 molded into the case - that's the GM part# for the tire pressure sensor for your car.
If it were me, I'd do a search on eBay for that number and buy a used one. I just did a search and found that there are a couple for $30 with free shipping.
I got a new set of wheels and tires for my 2009 and bought a set of used sensors - they're working great 3 years later!!
You'll see some aftermarket ones on there also, but Bill Dearborn and others have reported that the Dorman ones have not worked too well. The Orange Electronics and Oro-Tek ones have good reviews. Butt....I've got 4 sets of wheels/tires/sensors for my 2006 and 2009, and I've had great performance from OE sensors in all my wheels, and I bought used sets for two of the sets of wheels.
When you get a replacement sensor, your tire shop should be able to simply break the bead and push down the sidewall so the can reach in and take out the valve stem and replace it with the sensor. If it were just replacing a sensor with another one, I wouldn't even bother balancing because the tire wouldn't be moved on the wheel and the sensors weight the same. I guess in your case the sensor weighs a tiny bit more than just the temporary valve stem they put in, so have them rebalance the wheel.
Then, as others have mentioned, you'll need to reprogram all 4 sensors into the TPMS computer memory in the car - and you can see in the video below that it only takes a minute or so.
BTW, if anybody needs a tool like in that video, I have two available: a used one for $130; and a new one for $150.
EDIT: I see John O responded while I was typing - I'd take him up on his generous offer!!!
Bob
Those of us that run roadcourse track events can have real serious problems when a sensor goes bad during a track session!!!
The AH cannot be put into Comp or turned off completely, and if it was in one of those modes when the failure occurs the AH comes back full on automatically. Or if you lose tire pressure it will do the same thing, and that's what it really is designed to do - protect you when a tire loses pressure. The stiff sidewalls of run flats don't give handling feedback indications when you lose pressure going straight down the highway, so if you do lose pressure the AH gets REAL intrusive to keep you from taking the off-ramp in a spirited manner and losing control when a side load builds up in a turn.
When you turn aggressively the AH puts on individual brakes - and as far as I know the brake lights don't activate, so the guy behind you can have real issues as your car starts slowing down and probably jerking around!!!
When you try to accelerate out of the corner you get NO throttle response at all until you've got the lateral G and yaw rate down to bassically zero and the steering wheel is straight - only then can you accelerate down the track!
It messes up your whole track experience, and can cause big problems if somebody is following close behind!
I had trouble programming one of my sensors after putting on a different set of wheels/tires/sensors at the track. I normally run in Comp mode, but couldn't select it. I thought "how bad can it be - I'll just go out for this session without the sensors programmed in and run with the nannies full on".
BAD IDEA!!!! I got those symptoms explained above, and limped around and back to the paddock. I got out my TPMS tool and put new batteries in it and got all the sensors programmed properly, and went back out in Comp mode and had no more problems.
Driving on the street you probably won't experience any problems, unless you want to go into Comp you can still turn TC off, but not the AH. If you're carving up a canyon road or doing some other spirited driving you'll probably notice it.
Bob
BTW, the glue part was where a previous installer had broken the sensor portion from the valve stem and attempted to glue it back together.
