4LT Dash Pad problem!!!
#202
Easier said than done. My insurance company will want to see the damage(not a problem), they will assign one of 4 or 5 glass companies they use( none of which will wait for me or a professional to work on the dash), and it affects my insurance( $500 deductible). Pulling the dash is cheaper. I've thought of convenient damage to the windshield.
#203
Plus if you have HUD insurance would pay for a regular windshield and you would have to pay the difference for the HUD compatible windshield.
#204
About $650 to fix
You will have have dash taken off. You to have professional do this. It is a must. There are companies that only take off dashes and reinstall them. Talk to a collision repair place. They know who to contact. Mine cost $500. The dash can be reglued about $150. Then invest in a high quality ceramic front window tint. $150. It will reflect 51% of the heat. I also put a sun Shield in window. Mine is only in the sun about 10 hours a month. I have a 2008. It happen to me last summer.
#206
It is also not uncommon for a glass company to remove a windshield and then reinstall it a day or two later. This happens when car windshield frames or roofs are replaced.
I'm not advocating you commit insurance fraud. I just thought I'd share that information because it seems you have been misinformed or you made incorrect assumptions.
#207
For what it's worth, I pulled my dash in my C5. It wasn't that difficult or time consuming. If you have any experience working in interiors, you should be able to do it yourself with the help of this forum and YouTube.
#208
#209
A dear friend, and 2009 4LT owner and resident of San Marcos, would agree with you entirely. His problem, however, "reared its ugly head" prior to his 3/36 expiring -so- it ended up simply being an inconvenience.
Here's wishing good luck to all others who have encountered this, not so uncommon, problem !!
Cheers !!
Gary
#210
Received 2,051 Likes
St. Jude Donor '13
Your insurance company cannot dictate where your repair is made, by law. Also, glass deductibles generally are not the same as your comprehensive or collision deductibles. Glass replacement is often free of deductibles, once per year. If you haven't looked at your policy, you should.
Our C5 definitely was.
#211
Reasonable Fix
Mine was totally peeld up from around the HUD bezel and like a small mountain for about 1/3 of the dash pad. I got absurd quotes on fixes for this:
New Dash ~$3K
Pull windshield and repair- $600 (and if windshield breaks + 1300)
Even took it to an upholstery guy to see if he could do it installed ($200). He tried and said he could not. So....
I looked at it and thought, "If I pull the speaker and HUD bezel, I can do it"!
The front of the pad was loose, so I just peeled it back like a blanket at bedtime. I applied permatex cement and "quickly" peeled it back forward. The cement has to cure 10 minutes before adhesion. so I had a little time to get everything flat. It did a fairly reasonable job. Got some on the windshield, but it comes of with paint thinner and a razor. A couple of minor kinks, but nothing like it was before. Total cost: $4.02 incl. tax!
I was amazed that there appeared to be no adhesive at all under the pad. To me, it is not worth it to put hundreds (or even thousands) to fix cosmetic issue for a car worth less than $30K.
New Dash ~$3K
#212
Could you reference that please? If they had a guy that would do it for $200 and I found a guy that would do it for $400, the insurance guys have to pay? I would think they absolutely could tell you where to go. And the laws would be different in every state.
#213
Insurance companies try to steer you to their body shops by offering guarantees/warranties on the repair or perhaps requiring you to have your damage inspected at one. They cannot, however, require you to use them.
#215
OK Tech, I gotcha now. So IF "my guy" costs more, the insurance would only pay whatever they pay. I ask because I was considering getting the windshield pulled (it had a repair 4 years ago), but Safelite said they wouldn't remove the glass one day and install it on another day. I know a good local guy that would have no problem doing it.
#216
Received 1,194 Likes
St. Jude Donor '15
Regardless, I'd just pull the dash and be done with it
#217
The insurance company is not obligated to pay more for a job than what's normal in your area. However, assuming that "your guy" has reasonable labor rates, he would request a supplement from the insurance company for the difference. You just drop your car off and "your guy" will work out the supplement, if necessary. Body shops don't get blank checks from insurance companies for repairs, but they can request additional money and provide supporting documentation of the labor and materials required to repair it properly. This is _very_ common.
#218
Work complete
I just got the car after 7 days in dealership limbo. The dash cost $170 to repair and it looks great. The upholsterer used glue but added staples where he could. Should hold. The cost to pull and reinstall the dash was $474 out the door. While there I had them fix a "low beam" recall issue and replace the catalytic converters before the warranty is up 02/17. So the car is back to its old self for a grand total of $644. Not bad considering what it could've cost. Now I'm going to get the front glass tinted and shop for a tasteful, effective dash pad. Thanks for all the helpful hints.
#219
I am so freaking pissed off.
2012 Grand Sport, 28k miles, always garaged, 4LT Centennial edition. Got it in to drive today and thier is a huge *** bubble in front of the defroster vent.
Who do I contact at GM, pretty sure a dealership will be worthless.
#220
I hate to tell you this but my experience to date is no one is going to help. You are on your own 😖😭😢
