Does anyone make aftermarket wheels under $3000 that will clear C6Z brakes and not stick out of a stock coupe fender. I dont care if they are stock size just clear the caliper and not stick out, is this possible
TSW Rotary Forged Nurburgring wheels. I got mine through Discount Tire. They clear Brembo Big Brake Kit! 1/2" wider front & rear, LIGHTER than OEM and about $1200/4 (18/19 & 19/20) for base coupe/vert.
19" rear wheel w/base C6 brakes (Delco slotted-drilled rotors)
19" rear wheel with Brembo Big Brakes ($7500)
...and the the 18" fronts with the REALLY BIG BREMBO!
I really wanted ccws but they said they could not make them clear the breaks and not stick out. Thanks for the responce i think i will be going with the TSWs
Ace R1 with 305's in rear. They don't stick out and for 1000.00 for 4 they are cheap enough. I'm told they clear big breaks but I haven't tried myself.
thanks for the responces. Im most likely going with the TSWs. The ace slicks look to much like stock Z06 wheels and im not a fan of that style. I already have black Z06 spyders.
I suggest you check with John at CCW. IMO you can't do better that CCW wheels and John's a fitment expert.
I did and John said he could supply his wheels to allow Z06 size tires on a standard non-wide body C6 but the rears would not clear a Z06 brake upgrade. The fronts would.
If you have no plans to upgrade your brakes, then CCW has a solution. If you plan on a big brake upgrade in the future, CCW does not have a solution per John.
Now if you aren't interested in Z06 tire sizes, then maybe they can accommodate the big brake calipers. I didn't check that out.
Ace R1 with 305's in rear. They don't stick out and for 1000.00 for 4 they are cheap enough. I'm told they clear big breaks but I haven't tried myself.[/IMG]
I just went to Ace's website and they do not list any wheels for the Corvette.
