The other day, temp in high 50's low 60's I left my house and went about 6 blocks to the only stoplight in town. Tires were still cold of course. Light goes green and I am making a 90 degree left turn. No cars around. I step on it and my *** end starts to drift around as I am accelerating. I was not punching it only accelerating hard. Should my active handling caught this? I have never had a vehicle with AH or TC so am not all that familier with the systems. 2011 GS. Thanks, Grant.
Honest answer, no it should not have caught it.
Active Handling can't defeat the laws of physics. Had you stayed in it, Active Handling would have likely started in intervene and started applying brakes but still would not have likely prevented the inevitable spin under those specific circumstances.
Let's see....cool temperature, cold tires, 90 degree turn and you "step on it." I think the outcome is predictable with or without the nannies. I recommend leaving the nannies on for everyday street driving. TC and AH may help in certain circumstances and they may hurt in some circumstances but under no circumstance are they a fail-safe.
Same thing used to happen to me in my 05 coupe when leaving my mother's nursing home. Had to make a 90° left as I left the parking lot. Least bit of gas would make the rear end slide a little. It doesn't take much when the tires are cold.
be very very careful in these cars - the back end will overtake your front end in a jiffy AH/TC notwithstanding - when temps are even a bit low do not hit it hard, I've almost taken out a car when trying to overtake it on dry pavement
AH will allow the rear end to step out quite a bit before activating. Best way to find out what will happen is to go to a large empty parking lot and try and see how much it will step out before AH intervenes.
Rear end snapped around on me pretty quick yesterday merging and not accelerating very hard. Only 47* and out and original Goodyear tires so I guess what do you expect.
Bill
The basic concept:
Active Handling compares your speed & rate of turn, with the steering wheel position. If it senses "too much" disagreement, either turning "too fast" for the steering wheel (oversteer) or turning "too slow" (understeer), it will intervene. Poor traction due to cold weather or wet roads, merely causes everything to happen sooner.
As others have commented, the AH on our C5 was rather sensitive and would intervene sooner than I liked, I usually drove in Comp mode unless the roads were cold or wet. The C6 system seems to be set "looser" and will allow more slip or slide before jumping in.
Thanks all for the feedback! Bill Dearborn, I will try as you said as my tires are ending the end of their life and should get some schooling at that time. Grant.
Your Active Handling may not have been "on line" at the time of the incident. According to the owner's manual, it could take the system as long as 15 minutes to fully warm up and become active under some conditions.
Regardless of where the back of the car was (within reason), were your front wheels pointed in the direction the car was going? If so, AH had nothing to correct.
