Fuel tank question..
Old Nov 2, 2012 | 09:55 PM
Stevenyc777's Avatar
Stevenyc777
Default Fuel tank question..
With gas being almost impossible to get in the NYC area (2-4 hour wait)going too syphon gas out of the vette too put in my d.d.my question is i know the C6 has 2 tanks so when i take fuel out of 1 tank does the fuel in the 2nd tank automatically go into the 1st and do i need too have the car running? Anyone ever do this? Tx
Old Nov 2, 2012 | 10:21 PM
SimpleC6's Avatar
SimpleC6
Wish I could help you out but I don't think that's how it works, though. I think there's a valve and it drains one tank, and then the valve switches it to the other tank, but I'm not that sure.
I hope you get it figured out, and good luck.
Old Nov 2, 2012 | 11:11 PM
Stevenyc777
Ttt
Old Nov 2, 2012 | 11:17 PM
SilverScorp's Avatar
SilverScorp
I don't know the answer to your question, but siphoning out gas while the car is running can't end well. I've been watching the news and I surely wish you the best up there as things are starting to look like a Madmax movie up there.
Old Nov 2, 2012 | 11:33 PM
05C6B4U's Avatar
05C6B4U
I would imagine car, or at least the fuel system, is required to be On for the fuel to move from one tank to the other tank. Tank #1 is on the driver's side and tank #2 is the passenger's side. During fill up, #1 fills, then #2. During use, #2 empties first, then #1.
See:
http://forums.corvetteforum.com/c6-c...ks-or-one.html
Old Nov 2, 2012 | 11:48 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I believe, the tanks pretty much equalize when the car is in use. If you siphon some gas I'd stop at some point, start and run the car a bit. I'd guess that should equalize the fuel level(s) between the two tanks before you start siphoning again. I think even when the fuel gauge reads empty there's still some fuel in the tanks. I wouldn't try to completely drain the Vette. Good luck and I hope life returns to normal for everyone soon.
PS I don't understand why obama doesn't order military fuel trucks to the afflicted areas. I don't expect the government to give fuel away but they could setup a portable, cell phone credit card system and sell the fuel to people at cost. It would make life a bit easier until services are restored.
Old Nov 3, 2012 | 12:31 AM
Stevenyc777
Thanks for the response guys...our damn mayor just cancelled the nyc marathon its amazing that he wanted it in the first place!
Old Nov 3, 2012 | 06:58 AM
EuroRod's Avatar
EuroRod
From recently speaking with a GM Tech, there is a secondary pump in the right tank that equalizes the level of fuel in both tanks. So, I would guess that if the C6 has fuel, and you drain the first tank, by simply starting the car and allowing it to run for a period of time, the tanks would again balance out, and you could drain some more.
Old Nov 3, 2012 | 02:06 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by Wayne O
I don't understand why obama doesn't order military fuel trucks to the afflicted areas. I don't expect the government to give fuel away …
That is now being done. 12 million gallons, 10 gallon limit per person, free.
Old Nov 3, 2012 | 03:52 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you can find a parts store that's open, or borrow one; get a cheap hand pump instead of siphoning. You don't want a mouth full of gasoline in addition to all the other problems.
Best of luck to you and all in the area.
Old Nov 3, 2012 | 03:59 PM
*Ragin Cajun*'s Avatar
*Ragin Cajun*
Link please. If this is true this is nothing more than the Democrats handy work for votes.
Old Nov 3, 2012 | 04:15 PM
EVRose's Avatar
EVRose
I heard on the news this morning that it is true.
Old Nov 3, 2012 | 04:29 PM
John Harry's Avatar
John Harry
http://usnews.nbcnews.com/_news/2012...must-wait?lite
Yeah, devious Democrats trying to help people. They should be ashamed.
On a more C6-related note, doesn't the Vette have an anti-siphon valve of some kind?
Old Nov 3, 2012 | 04:52 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
They started putting in anti siphon screens in GM cars in the early 70s do to a "gas crises". To the best of my knowledge they still put the screen in. Have not tried to siphon gas lately but I have tried in a few cars since the 70s and the hose only goes down a few inches.
Old Nov 3, 2012 | 05:02 PM
Motorhead-47's Avatar
Motorhead-47
There is quite a bit of misinformation in this thread to include the info from your GM Tech. The passenger side tank empties first followed by the driver's side. When your gauge reads half full your passenger side tank is empty and the driver's side tank is full. When you refill you refuel the driver's side tank first and then it flows via the crossover tube to fill the passenger side tank. Follow this link and read through it carefully. Your GM tech is wrong. Although this link references late C5's...the system is identical in the C6 Corvette...
http://www.hessh.de/Corvette/FuelTankSystem.pdf
Old Nov 3, 2012 | 05:03 PM
raspyc6's Avatar
raspyc6
I never knew that our c6's had 2 tanks. This site is cool for new finds like that.
Ragin Cajun made me spit my bottled water at the screen. JustinJor told me about you, man...all good of course.
Good luck to all you fellas in the Northeast.
Old Nov 3, 2012 | 05:08 PM
Admiral Ballsy's Avatar
Admiral Ballsy
There's a ball-style check valve in the filler neck - it's there to prevent leaks if the vehicle rolls, but it also serves to prevent siphoning. You can't get a hose of any kind of size past it; you might be able to get something like aquarium air line past, but it'll take forever to get any kind of throughput with that.
Of course, if time is all you have...
To Fuel tank question..
Old Nov 3, 2012 | 05:11 PM
Larry/car's Avatar
Larry/car
What on earth is wrong with you. People are devastated, lost everything and your worried that the Democrats are helping to get votes. The president is doing his job!!!
Old Nov 3, 2012 | 10:14 PM
Stevenyc777
So has anyone tried this? Am i able to get fuel out or is there an anti syphon mechanism in there? I do have a totally full tank in the vette...this sux!!!!
Old Nov 3, 2012 | 11:01 PM
fnsblum's Avatar
fnsblum
Drive the Vette. Later! Frank
