Dead Battery
Old Dec 13, 2012 | 02:09 AM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Default Dead Battery
Battery went **** up today. Didn’t recognize the fob and when I push the starter button all I got was the starter ticking noise. Checked it with a voltmeter and it read between 9-10 volts. Checked the starter wires they appear to be OK. Took it out and hand the guy at Auto Zone check it and he said the battery is good but it needs a charge. I left it overnight for a good charge. I bought the battery in August 2012 from them. Within the last couple of months, I’ve driven the car at least twice a week to the store and back about 2 miles round trip. I never had any problems since I replaced the battery in August. Is there some way you can tell if the alternator is charging. Back in the days all you had to do is remove one of the cables and if the car continues to run your alternator was good. Need some advice on how check to see if it is charging the battery. YES I know I need to drive the car more often. Planning on driving to Atlanta, Ga. then out to Charleston, SC next week.
Old Dec 13, 2012 | 03:03 AM
Don Nolan's Avatar
Don Nolan
Uh no........ You don't want to pull the cables off of your car while it is running....... I would guess that since you are making such short trips, maybe you aren't driving the car long enough to replace the juice you used to start the car. From now on, take the "long trip around the barn" and see if that cures your problems. I.E. Drive it a little farther and maybe the battery will get a better recharge. Or, if you are going to continue to drive such short distances, put a charger on you battery every so often.
Old Dec 13, 2012 | 06:40 AM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
I would keep the car on a battery tender $20-$25, available everywhere...
Old Dec 13, 2012 | 06:46 AM
Don-Vette's Avatar
Don-Vette
I would have your charging system checked.
Old Dec 13, 2012 | 06:51 AM
Landru's Avatar
Landru
Get & use a battery tender.
The amount of time you're driving it probably isn't enough to recharge. They say it takes minimally 20 minutes following a start-up.
Even when routinely driven these cars are murder on batteries, as it is.
Whenever I've put my tender on following a cruise in excess of 90 minutes, the tender always shows it's charging the battery. Make of that what you will.
Otherwise, any qualified shop can check an alternator's output.
Old Dec 13, 2012 | 07:27 AM
TerryL's Avatar
TerryL
St. Jude Donor '17
Chaparral Motorsports has the Deltran Jr on sale for under $25.
Old Dec 13, 2012 | 08:06 AM
hawkandersonjr
Thanks for all the advice. I will pick a battery tender today. I will also have them check the charging system and for sure drive it more.
Old Dec 13, 2012 | 09:16 AM
NevadaVette's Avatar
NevadaVette
The old alternator test still works.
Old Dec 13, 2012 | 09:24 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Driving the car a couple of times a week for 2 miles is actually using more charge from the battery in entry, startup and exit than you are replacing during the drive. You'll likely need just about 30 minutes of driving to replenish what you are using just starting up and getting in. Of course factors like HVAC fan settings, radio, lights, etc. are all variables as are RPM's while driving.
As you've noted, do yourself a favor and get a good battery tender.
Old Dec 13, 2012 | 09:25 AM
dvilin's Avatar
dvilin
Should do it. I have found that hooking up the battery tender is so easy I just keep it hooked up all the time the car is sitting, no matter how long that may be.
Old Dec 13, 2012 | 10:15 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Ctek MUS 4.3 instock and shipping daily 79.99 shipped and includes the cig lighter plug as well!
This one will also recondition your battery too
http://shop.doubledmods.com/CTEK-MUL...?categoryId=-1
Old Dec 13, 2012 | 10:20 AM
Jimini's Avatar
Jimini
Old Dec 13, 2012 | 10:34 AM
Top_Fuel's Avatar
Top_Fuel
...the guy at Auto Zone...said the battery is good but it needs a charge.
Hmmm...if a battery isn't fully charged there's no way to accurately test it, so I'm not sure what AutoZone guy was trying to say. You should fully charge the battery and then have it LOAD TESTED to make sure it really is a good battery.
...all you had to do is remove one of the cables and if the car continues to run your alternator was good.
That test may be OK on a 30 year old car, but NEVER do that on a modern vehicle full of expensive control modules and circuit boards. You may induce funky voltage spikes that can cause all sorts of problems.
Set your DIC to read battery voltage. You should see 13.5-15 volts while you are cruising down the road.
Old Dec 13, 2012 | 12:31 PM
hawkandersonjr
Thanks for the info. They fully charged the battery and I took the car to Auto Zone and they did a load test. It passed, will get battery tender and do a little more driving.
Old Dec 13, 2012 | 12:43 PM
carnut08's Avatar
carnut08
I've used a Battery Tender since the car was new in September of '07. Battery is still good. I'm interested to see just how long it will last.
Be sure that you connect the tender to a surge protector when you use it! You will not be sorry if you follow this advice.
Old Dec 13, 2012 | 12:52 PM
hawkandersonjr
Default Stability Control
Well today makes a year since I bought my 05 Vette in which I had to replace the battery yesterday because I don't drive it enough to keep the battery charged up (battery tender on order: ***** . I notice something today that the Stability Control light came on when I got down on it a little and the tires squealed. Should I have the Stability Control on at all times or just when I want drive a little aggressive?
Old Dec 13, 2012 | 02:38 PM
cclive's Avatar
cclive
Simple charging system check is that if the voltage displayed on the DIC is above 13.2 when the engine is running, all is well.
When you break the tires loose with power, the traction control and/or the active handling will engage...this is normal. I would suggest leaving it on unless you are on a track.
To Dead Battery
Old Dec 13, 2012 | 02:43 PM
CO Lightfoot's Avatar
CO Lightfoot
From another thread:
Originally Posted by CO Lightfoot
For a weekend car, definitely use a good battery maintainer.
You can connect directly to the battery. That's what I did when I first got my CTEK. Then I experimented with other methods.
Bottom Line: IMO it's more convenient to use CTEK's optional outlet adapter. http://www.amazon.com/CTEK-56-263-Co...=pd_sim_auto_1
Either outlet works fine. I use the center console outlet because that's where I store the adapter.
And I leave the lid open as a reminder to disconnect it before driving away.
Just make sure you don't crimp the cord -- it should move easily when the door is closed.
Lots of threads on this topic, like this:
http://forums.corvetteforum.com/c6-c...r-hook-up.html
http://forums.corvetteforum.com/c6-c...-question.html
Old Dec 13, 2012 | 03:25 PM
VET4LES's Avatar
VET4LES
As stated in above post there is no way he could give it a load test until it is fully charged.
Old Dec 13, 2012 | 06:25 PM
sstadt's Avatar
sstadt
1st Gear
Yes, using a tender will solve your problem. These cars seem to drain the battery with minimum use, so have a good quality battery tender at hand and use it frequently. Walmart sells one at a good price and it is quality.
