ice possible
Old Jan 6, 2013 | 01:08 PM
pkriner's Avatar
pkriner
Default ice possible
Its around 50degress outside and my car is reading-30 sayin ice possible is this signs of a bad computer
Old Jan 6, 2013 | 01:27 PM
VCUFAN's Avatar
VCUFAN
Curious how you picked the parts for sale/wanted section as a good spot for your post. Not sure what this post even means. Good luck
Old Jan 6, 2013 | 01:40 PM
pkriner's Avatar
pkriner
Damn i didnt mean to post this here lol
Old Jan 6, 2013 | 03:12 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Well, it's showing up in C6 General now...
OP might have some kind of sensor or computer problem, but I'd wait a bit to see what conditions make it come on again.
Also, it takes a while for the outside temp gauge to update if the temp has increased; details are hidden in the Mystery Book (Owner Manual). If you take only very short trips, it might NEVER update for higher temps. There is a way to force an immediate update; I can do it but can't explain it. (embarassed).
Old Jan 6, 2013 | 03:31 PM
Jimmy W1's Avatar
Jimmy W1
This isn't the for sale section. Maybe your computer is cold too.---
Old Jan 6, 2013 | 03:32 PM
FAsnakes's Avatar
FAsnakes
Veteran: Marine Corps
i wouldn't overreact.. . just keep an eye on it.
Old Jan 6, 2013 | 03:33 PM
Jimmy W1's Avatar
Jimmy W1
But in answering the OP's question: Maybe your garage was cool or damp and the computer picked up on it. Just keep an eye on it and see what happens.
Old Jan 6, 2013 | 03:40 PM
philip_g's Avatar
philip_g
Originally Posted by Jimmy W1
This isn't the for sale section. Maybe your computer of cold too.---
Uh, what?
Old Jan 6, 2013 | 03:44 PM
Jimmy W1's Avatar
Jimmy W1
Originally Posted by philip_g
Uh, what?
This is the "C6 General Discussion Section". It isn't the "FOR SALE SECTION".......
Ludedude's Avatar
Ludedude
The post was moved.
Old Jan 6, 2013 | 04:46 PM
philip_g's Avatar
philip_g
Guess you didn't get it...
Old Jan 6, 2013 | 05:20 PM
Mad*Max's Avatar
Mad*Max
did you try pressing the three combo to get the computer to update the temp - that would have determined if your sensor is bad
Old Jan 6, 2013 | 05:30 PM
Scruff Vette's Avatar
Scruff Vette
Old Jan 6, 2013 | 05:51 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by Scruff Vette
When the Front Defrost, Rear Defog and fan up buttons are pressed simultaneously.
Updates temperature display instantly.
Old Jan 6, 2013 | 06:15 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Check your Outside temp sensor located in the right front by the radiator shroud. You either have a bad sensor or it's unpluged. You can also do as mentioned above about resetting the temp first and then .....
Old Jan 8, 2013 | 01:05 AM
thegreenman's Avatar
thegreenman
That is how mine started acting up, 85 degree day and showed ice possible, next day it showed 75 degrees where it stayed. For me the HVAC control module was bad.
Try HVAC reset like mentioned above, check sensor (use ohm meter) or try R&R HVAC fuse.
To ice possible
