plug removal
Old Feb 2, 2013 | 08:44 AM
belsy's Avatar
belsy
Default plug removal
2005 C6 with original plugs at 130,000 miles!! Previous owner never touched them but I feel the need to replace.
Fear of ???? any suggestions to prevent problems when pulling plugs that old ??
Pre soak at head w/ penetrating solution i.e. liquid wrench, PB blaster or ???
Any suggestions or experiences with cautious advice is appreciated.
Thanks in advance:shrug:
Old Feb 2, 2013 | 08:58 AM
Kenny94945's Avatar
Kenny94945
Here are some tricks.
If really concerned:
1) Spray w/ penetrating oil over a few days (or at last some hours)
2) Loosen each plug 1/4 turn
3) Reattached wires and start engine for one minute - this breaks loose any carbon built up on the spark plug threads to heads in the combustion chamber.
4) Remove plugs
Take care removing the wires...use die-electric grease on the wires ends upon re-assembly.
Don't forget to check the plug gap and use a torque wrench for re-assembly.
A spark plug wire puller tool and dedicated spark plug socket are worth buying if you do not have these.
IMO C6 Vette plugs are fairly easy to access.
Old Feb 2, 2013 | 09:03 AM
chevy7398's Avatar
chevy7398
You will probally have a harder time getting the boots off the wires than you will removig the plugs fron the heads.
Old Feb 2, 2013 | 10:40 AM
ErnieN85's Avatar
ErnieN85
have a new set of wires on hand
Old Feb 2, 2013 | 11:03 AM
DSOMC6's Avatar
DSOMC6
And when you purchase new wires upgrade to MSD. They can be taken off/on multiple times without pulling apart and look cooler.
Old Feb 2, 2013 | 11:22 AM
MLCRookie's Avatar
MLCRookie
Just a curious additional question: Are the plugs on Vettes indexed from the factory?
Old Feb 2, 2013 | 11:31 AM
cclive's Avatar
cclive
You'll probably find that they come out just fine and also that they look just fine and you'll wonder why you messed with them at all.
wayback's Avatar
wayback
Don't forget to put some antisieze on the new plug before installing them.
Just changed my plugs and wires a few months ago. I had 82,000 miles at that time. No problems changing them but the old plugs were pretty worn out.
Old Feb 2, 2013 | 11:43 AM
C7/Z06 Man's Avatar
C7/Z06 Man
I would try breaking the plug wires loose "first" by twisting the plug wire boots before pulling on them and when pulling grab down by the base/front of the boot. Same goes on the coil side.
Use the stock plugs for no performance issues. The factory plug is very good IMHO.
Old Feb 2, 2013 | 11:49 AM
irok's Avatar
irok
like he said. dont even think of reusing plugs or wires no matter what they look like. remove them with engine cold
Old Feb 2, 2013 | 11:55 AM
C7/Z06 Man's Avatar
C7/Z06 Man
No.
Old Feb 2, 2013 | 12:08 PM
cclive's Avatar
cclive
No, they don't have time for things like that when assembling engines...even at Wixom.
Old Feb 2, 2013 | 12:47 PM
Don-Vette's Avatar
Don-Vette
Dielectric grease on top half of plug and a dab inside boot before slipping wires on. Never seize on plug threads as well. That is what I do.
toxin440's Avatar
toxin440
One thing I'm always extra cautious of is making sure you thread the new plugs in properly.
Not on the vette - but i bought an 05 S10 (used) and did all the easy maint. stuff. It had 60K on it so I did the plugs. Getting to them was a B*TCH, and threaded one cylinder wrong. it was a beater so I didn't care THAT much but still kinda sucked because I like doing things right. In the end I just super torqued it down to where it would probably never be removable again (lol)
Long story short it ran fine for another 50K miles till I hydroplaned and bounced the face off a concrete wall doing 50. So in the end it was all good (plug wise at least)
Did remove a few plugs on my LS7 to check for oil on the threads (somewhat related to the valve guide issue thats ongoing) and yeah it's harder to get the boots off than taking the plug itself off.
Be sure to put down and 100% secure the boot/wire when you are done though -- I had one pop off and caused me a rough idle and weird 6th gear judder when it was only running on 7 cylinders for a bit.
To plug removal
