Our 2009 C6 is about to reach 50,000 miles in the next month or so. So far, everything's been good; however, I was wondering what items should be replaced to ensure the next 50,000 go just as smoothly.
Things I've changed:
- Transmission Fluid and Filter
- Power Steering Fluid
- Front and rear brakes (at 45k)
- Cabin Air Filter
- Wiper Blades
- Tires (at 30k)
- Engine Air Filter
- Coolant Flush (because car sat on dealer's lot for 1+ year)
Do any belts need replacing before 150k? What about the PCV valve? The car is mainly used as a daily driver, so it gets started at least once a day and sees roughly 15-18,000 miles a year. The original battery's been holding up great, and the shocks have held up great even with the bumpy roads we have here in NYC. Any advice would be greatly appreciated.
- Cabin Air Filter
- Wiper Blades
- Tires (at 30k)
- Engine Air Filter
Thanks!
I don't know how batteries last in your area, but I'm on my third one already ('08) here in the Phoenix area.
The one item missing from your list is brake fluid. Flush anytime it turns real dark or black. If you DIY, do a search for the method.
Belts are good for 100,000 -150000 plus miles (assuming no harmonic balancer issues). No PCV valve to change !! Shocks seem to be good for 100,000+. Radiator hoses should be checked and changed when they feel brittle or start to swell up!! Flushing the brake fluid every couple of years is a good idea, Just don't run the system dry, purging the antilock brake module requires a specific computer controller to modulate the ABS system if you run it dry!! Other than that I think your on the right track for a long and happy Vette Life.
I changed the shocks in my 05 coupe at 55k with Billsteins. Great move, you won't believe the difference in the ride. Also, I make it a habit to change the differential fluid about every two years (I use the Amsoil 75-90 gear oil). If you've experienced the "clunking" sound when you back up, it's time to change the differential fluid. Good luck!
I had the spark plug wires swapped out at 50k miles and found cylinders 3,6 and 7 had no electrodes on the spark plugs...so I'd recommend swapping out the plugs...
I went with the bilstein sport shocks to replace my z51 shocks at the same time.
I did the cabin filter once and thats it. That in my opinion is a total waste of time....
Brake fliud change needed. The coolant change wasn't. It was a 5 year coolant. Sitting on the lot did nothing to degrade it. Wires and plugs are 100,000 milers.
Do you need any special tools or electronics to change the brake fluid / bleed the brakes?
If you do it the old fashioned way all you will need is a jack, jacking puck, a lug nut wrench/socket, a 1/2 in torque wrench for reinstalling the lug nuts, a 10 mm box end wrench for opening and closing the bleeder screws, something to suck old fluid out of the master cylinder reservoir and another person to pump the brake pedal while you open and close the bleeder valve and tell them when to push and hold and when to release. Also the new brake fluid. Bleed order is right rear, left front, left rear, right front. Bleed each caliper until new fluid comes out.
Bill
This method will not get the fluid out that is in the ABS reservoir, but I personally don't think that is necessary if you bleed your brakes relatively often. As I bleed mine after every track session, and use ABS on every track session, there is no need for me to have to activate the ABS electronically for a bleed. For those that only bleed once every five years or so, maybe a little more important, but not worth the time and money in my opinion. When I did my first bleed from DOT 3 to DOT 4 for the track, I bleed real well, took it out for a drive and activated ABS several times, then put it back up and bleed it again and called it good enough.
Checking in at 65,000 miles and counting. Aside from a dead battery issue and a tie rod issue from going over too many potholes, the car has been great! Thanks for all the advice, I've definitely been keeping up on maintenance and following your advice! At this rate we will be at 260k in 15 years (which is how long we usually keep cars)...
