C5Z Diff Swap Into 05
Old Mar 12, 2013 | 02:45 PM
ASarsano's Avatar
ASarsano
Default C5Z Diff Swap Into 05
well thanks to the bracket nicely made by stanger383
swapped a built 04 Z06 Diff with 3.73 Gears into my 2005.
Amazing the night and day difference, but unfortunately the stock run flats cant handle the new gears there far to aggressive and loses traction with even a slightly hard acceleration. Time to upgrade to some better tires then hit the track and see what it can do.
IMG_0488 by ASarsano, on Flickr
IMG_0489 by ASarsano, on Flickr
IMG_0490 by ASarsano, on Flickr
IMG_0491 by ASarsano, on Flickr
IMG_0492 by ASarsano, on Flickr
IMG_0493 by ASarsano, on Flickr
IMG_0494 by ASarsano, on Flickr
IMG_0495 by ASarsano, on Flickr
IMG_0496 by ASarsano, on Flickr
IMG_0497 by ASarsano, on Flickr
Old Mar 12, 2013 | 04:40 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Great pictures
Old Mar 14, 2013 | 10:43 AM
Justasheet's Avatar
Justasheet
Did you have to grind some fins on the bottom of the diff to make it fit? It looks like it in the next to last pic.
Jeff
Old Mar 14, 2013 | 09:43 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Glad to see it all bolted up. I was wondering if you had done the install yet...... Did everything bolt in ok? Any issues with the brackets? Glad you running well!!!
Old Mar 16, 2013 | 12:18 AM
ASarsano's Avatar
ASarsano
no issues got it in on the weekend. took a bit of cutting on the fins i wasn't sure exactly how much so i bolted it up jacked the frame up took a measurement and got the whizz wheel and kept cutting and testing till i had just enough clearance. wanted to leave as much of the fins as posable, for best cooling.
Might play around with some shims coming up, as the aftermarket 3.73 gears make an immense amount of noise. figure if i can shim it right i can quiet it down some so taking a call while driving will be posable if need be. lol
Old Mar 16, 2013 | 01:02 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
When i put 3.73s in my c5 they were quiet as stock... hopefully you can quiet them down
Old Mar 16, 2013 | 01:17 PM
Dragracer_Art's Avatar
Dragracer_Art
If you hear noise... you have a problem.
Did you check to be sure oil was in it ?
Old Mar 18, 2013 | 10:17 AM
ASarsano's Avatar
ASarsano
Yes there oiled up with royal purple gear oil. 2 QTs Not a grinding or wearing noise, just a wining which I've hear is common with non stock gears. We're the gears sit a little off from where factory gears ride on the spline
Old Mar 22, 2013 | 04:42 PM
Justasheet's Avatar
Justasheet
Did you figure out your gear issue?
Jeff
Old Mar 23, 2013 | 11:43 AM
ASarsano's Avatar
ASarsano
not yet, from what I've researched its just the gear set up which will need to be adjusted or shimmed. Not a big deal at the moment as the noise isn't wearing or doing and damage to any thing. Its just a noise, I've opened the diff up and checked no wearing or damage. so for now I'm leaving it as is. Eventually ill try the shims and if i cant get it where i want it look into having the diff adjusted or rebuilt. I think the biggest reason the diff makes noise is that fact that it was built for a C5Z06 with an aftermarket (upgraded) tranny so the diff was set to that tranny then pulled off and swapped into a c6, quite a change so the set up need adjustment on the backlash ext.
Old Mar 24, 2013 | 10:48 AM
Justasheet's Avatar
Justasheet
Did you use some rubber washers to mount the bracket to the diff? It looked like it in your pics.
Jeff
Old Mar 24, 2013 | 11:42 AM
ASarsano's Avatar
ASarsano
i honestly cant recall all the hard wear came with the bracket. deff a good point to look into.
Old Mar 24, 2013 | 03:32 PM
trayack's Avatar
trayack
I'm looking to do this too. The bracket stanger383 made for you, is it weld on or bolt on?
Old Mar 24, 2013 | 06:52 PM
saplumr's Avatar
saplumr
Spend the cash and upgrade to a newer C6 or even better a Z06 diff.
Old Mar 24, 2013 | 08:30 PM
trayack's Avatar
trayack
^....you write the check. I'm having to drop a lot more than I wanted to as it is on other upgrades.
Old Mar 24, 2013 | 08:47 PM
saplumr's Avatar
saplumr
I know, I just saw it in the other thread. You gotta do what you can afford.
Old Mar 25, 2013 | 12:23 AM
ASarsano's Avatar
ASarsano
he made me the bolt in one. I chose not to go with the newer c6 diff as then u would need to swap the tranny extension housing as the bolt patterns for the 05 is unique to the 05 only (same bolt pattern as the c5) so it much more involved then just buying the 3 times more expensive diff. that was a major decision factor for me. then the fact that i had a built C5Z diff with aftermarket 3.73 gears laying in the garage I had built for my old C5.
To C5Z Diff Swap Into 05
Old Apr 1, 2013 | 01:56 PM
trayack's Avatar
trayack
Are rubber isolaters between the diff mounts and the top metal adapter plate? I just got Norma's kit and didn't see any included.
- Travis
Old Apr 1, 2013 | 03:20 PM
Justasheet's Avatar
Justasheet
Sure looks that way but Norm said he didn't use any. Something the OP must have done.
Jeff
Old Jun 11, 2024 | 05:46 PM
johnathan howard's Avatar
johnathan howard
1st Gear
Default In need of the c6 to c5 diff mount I hear a guy named 383 stranger makes them?
[QUOTE=ASarsano;1583344386]well thanks to the bracket nicely made by stanger383
IMG_0495 by ASarsano, need this c5 to c6 diff mount please give me this guys phone number or way to get in touch with him please!!!
