Correct oil level
Old Mar 29, 2013 | 02:00 PM
iclick's Avatar
iclick
Default Correct oil level
When I purchased my new C6 almost a month ago I noticed the oil level was a bit above ½ qt. above the full mark on the dipstick. Assuming the original oil was added at the factory I didn't think much of it, but after having a free first oil change done at the dealer yesterday I find that the level is still showing about the same level. The owners manual is very explicit with its warnings about having oil level outside the cross-hatched area of the dipstick.
In the photo I've marked the level and would like opinions on it. The dealer is checking how much oil was actually used, but I assume it was six quarts. If so, do I go by the six-quart spec or the dipstick to determine the proper level?
Old Mar 29, 2013 | 02:42 PM
ChevyDave's Avatar
ChevyDave
well, did you check when the car was on a flat and level surface?
if your saying the white line is where the oil level shows, that seems more than a 1/2 quart.
i assume your pretty smart at checking oil, so please dont think i'm being a smarty pants... but..
i have found in some cars that you need to wipe the dipstick and check, repeat 3 times. oil on some dipsticks will climb up when going in and out of the tube and need a couple readings to get accurate readings.
grrr... i never looked to see what year and model you have.
one thing you can do, it seems sorta unreasonable, but you can have the dealership pull another dip stick and put them side by side to check on their length.
my thoughts
oh, dip stick is the proper measuring method, uless the dipstick is too long.. which i doubt
Old Mar 29, 2013 | 03:05 PM
Kvothe's Avatar
Kvothe
I'm guessing you are checking the car cold. If you check your oil level about 10 minutes after being out on a drive I'm guessing you'll be right on where you should be.
Old Mar 29, 2013 | 03:12 PM
iclick's Avatar
iclick
Thanks for the replies so far.
(1) I check the oil level as per the manual--i.e., after normal operating temps are reached, above 200°, then let it sit for 5-10 min. The white line is a mark I made in Photoshop to show the level, as otherwise it didn't show up well in the photo.
(2) I did make several checks, wiping each time, and they were all the same. Furthermore, every time I check the oil hot it reads at this level. When cold it is even higher, showing almost a full quart high.
I got a call from the tech who did the oil change, after I inquired at the dealer earlier, and he said he used six quarts. He also said that they had seen some dipsticks that were crimped wrong at the bottom causing the tube to fit too far down, which then would indicate high readings. He's going to check it next week when I have the car in the shop for something else. In the meantime I'm going to leave it alone, as I must assume the factory put the right amount of oil in the car during assembly. If not it would be even harder to believe the dealer would make the same error when they changed it yesterday.
Old Mar 29, 2013 | 03:15 PM
ChevyDave's Avatar
ChevyDave
(1) I check the oil level after normal operating temps are reached, above 200°, then let it sit for 5-10 min.
I got a call from the tech who did the oil change, after I inquired at the dealer earlier, and he said he used six quarts. He also said that they had seen some dipsticks that were crimped wrong at the bottom which showed high readings. He's going to check it next week when I have the car in the shop for something else.
cool!! omg i never thought about crimping & hole punching wrong, thought about total wrong length of dipstick. good catch there!!!!
Old Mar 29, 2013 | 03:16 PM
Kvothe's Avatar
Kvothe
(1) I check the oil level after normal operating temps are reached, above 200°, then let it sit for 5-10 min. The white line is a mark I made in Photoshop to show the level, as otherwise it didn't show up well in the photo.
What year is your vette? Never mind I see you said new.
Old Mar 29, 2013 | 03:45 PM
ChevyDave's Avatar
ChevyDave
the GM number on my 2011 GS A6 dipstick is this...
i measured my hash area, then yours, they look pretty much identical in length.
Old Mar 29, 2013 | 05:08 PM
iclick's Avatar
iclick
Same part number with an "AT" in place of your "WA". If as the dealer tech explained the tube is somehow inserted in the block deeper than normal it would explain the high reading.
Old Mar 29, 2013 | 05:09 PM
TripleAstyle123's Avatar
TripleAstyle123
Old Mar 29, 2013 | 05:38 PM
gbrtng's Avatar
gbrtng
I see the same on my 2013 LS3 - So I'm making the rash assumption that the factory is putting exactly 6 quarts in the system and not a drop more ...
Old Mar 29, 2013 | 10:07 PM
Rogers 07's Avatar
Rogers 07
Depends on your car and year, If you have a manual trans and Z51 optioned car you have an oil cooler and it will hold 6 qts. Auto trans (A6) and non Z51 cars do not have the cooler and only hold 5.5 qts !!
Old Mar 29, 2013 | 10:33 PM
ChevyDave's Avatar
ChevyDave
sounds like OP has new as in 2013.
if its A6 ls3 6.2 L (wet sump) , with filter, i believe 6 quarts is accurate.
Old Mar 29, 2013 | 11:23 PM
iclick's Avatar
iclick
Yes, 2013 base coupe with M6. Six quarts is the spec according to the manual.
Old Mar 29, 2013 | 11:48 PM
Boomer111's Avatar
Boomer111
Checking oil level when cold vs hot will give two different levels read.
Just went through this very situation for the first time.
I always assumed with a procedure of filling engine with oil then running the engine just to circulate oil a bit then turn off and check rather quickly, then top off as needed. I believe this will show a high hot oil level of 1/2 quart.
Am I to believe that the LS3 is a "Hot Oil" reading dip stick?
Old Mar 30, 2013 | 10:03 AM
pahlbfishn's Avatar
pahlbfishn
I have a '13 A6 and the manual indeed says 6qts with filter.
Old Mar 31, 2013 | 07:05 PM
iclick's Avatar
iclick
Mine doesn't make that much difference, showing about ½-qt. high when hot (after a short wait) maybe 3/4-qt. high when cold.
Old Mar 31, 2013 | 07:57 PM
Red08's Avatar
Red08
I bought my '08 with about 21,500 miles. Before I drove it home, I checked the oil with the engine at operating temp. The oil level was about 1/4 inch above the full mark. When I got home, I decided, for piece of mind, to change the oil / filter.
I carefully measured the amount I drained from the pan, and collected from the filter. There had been a full 7 qts in the engine. My owners manual says to add 5.5 qts with filter, which is what I did. My oil level now, when warmed up, is right at or just a hair below the full mark.
To Correct oil level
Old Apr 8, 2013 | 11:45 AM
iclick's Avatar
iclick
I drained ½-qt. from the engine yesterday and the oil level now shows just a tad above the full level (top of hatch marks), which I guess is close enough. If the dealer used six quarts that would imply that the correct quantity is 5.5 qts. for this car, including filter.
I also looked at the service invoice from two weeks ago where I got a free oil change, and it shows that they installed seven quarts. Remember that the level was about the same as it was when I took delivery of the car with four miles on the clock, and they said they don't alter the factory fill on new cars. I'll ask them about the seven-quart item on the invoice when I visit them next, probably this week or next. All this is really confusing.
Old Apr 8, 2013 | 02:49 PM
corvetteflier's Avatar
corvetteflier
6 quarts with filter is correct for my '13 A-6. The tranny type makes no difference. The factory fill, cold, looked about 1/2 qt high. Haven't checked hot, yet, but I would guess it would be about at the top of the hatchmarks. Racing trick has always been to add a quart extra, so being a 1/2 qt, +/-, high presents no problem to the engine. My only complaint is the TPMS--just like on my '06, reads about 3 pounds low, hot or cold. However, as this was a consitent delta, never bothered me.
Old Apr 8, 2013 | 02:53 PM
LEAVINU's Avatar
LEAVINU
Doesn't the manual show "capacities"?
I always run a 1/2qt or tad more than the book because at 7k rpm it's gonna need it.
