Aftermarket alarm guru help /not connected to factory wiring
Old 05-02-2013, 01:10 PM
wteceraser
wteceraser's Avatar
Default Aftermarket alarm guru help /not connected to factory wiring
Can I hook up aftermarket camera alarm with tilt sensor and proximity sensor ?completely independent of factory wiring Thinking can hook up this way .Two red power wires directly to battery ,ignition on wire hooked to heated seat fuse.Will this work?Should I put additional fuse on ignition on wire ? Also,when combining two sensors do I need diodes and do I put diodes with current coming from sensors to alarm or current from alarm to sensors ?Thx for any help
Old 05-03-2013, 09:26 AM
wteceraser
wteceraser's Avatar
Well I guess I'll just have to try it and see if it works .
Quick Reply: Aftermarket alarm guru help /not connected to factory wiring
