Has anyone built a master blaster car dryer?A new one is 330 bucks.I work on jet engines for a living but cant figure a way to get one home.Someone has a good idea let me know
Just cough up the 330 and you will be very happy with it. The guys that are happy with their leaf blowers have never used a master blaster and have no clue on what a difference 8 hp makes. 58,500 feet per minute is just crazy
I take my car to the local "Splash" HAND WASH for $17.00 & I get a FREE wash every 10th wash, also if I get it washed, & it should get dirty within 3 days they redo it for FREE..
No brushes or spinning things hit the car, just big mittions on the washers hands, & they also put tire black on the tires! & do the windows inside.. and of course vacuum it... in fact they use a towel and clean the 4 exhaust tips .. A VERY NICE JOB..
I hated to spend the money, but it's a good investment. Washed my car this morning and took 10 minutes to dry it with warm air. Made a pita job real easy.
I wonder how Metro equates Horse Power to Amps. It is a know fact that 1 HP = 746 watts (in round numbers). They say you need a 20 Amp circuit to run their 8 HP (peak) motors (2 4 HP motors). If they truly have two 4 HP motors you would have:
8 HP * 746 watts / 120 volts = 49.73 Amps to run these motors. They claim 19 Amps.
Although I do not contest the fact that they are great machines, how do they make such a claim?
58,500 ft/min air flow what exactly dos that mean?
I'm sure it does a great job and I might buy one if I get tired of drying mine by hand but don't the stats sound a little over the top.
Last month I bought one from a friend, used, for $100.. Stopped at Lowe's on the way home.and picked up a 12', 1 1/2" shop-vac hose for it.. Made all the difference, now have a total of 22' of hose.. Oh yeah, I'm totally pleased with it.. And I too had been using my grass blower for many years..
I was thinking a leaf blower mounted to garage ceiling adapt a hose to it and give it a try.i guess i will buy a blaster sometime not just yet. Thats too easy.
[QUOTE=MKenM;1583816870]I wonder how Metro equates Horse Power to Amps. It is a know fact that 1 HP = 746 watts (in round numbers). They say you need a 20 Amp circuit to run their 8 HP (peak) motors (2 4 HP motors). If they truly have two 4 HP motors you would have:
Never thought about it before but the math above is correct, they have to be lying about the horsepower rating, even if only one motor was running at a time you would still be over the amperage rating.
The 8 hp is the units output; 19 amps is its electrical consumption. One does not equal the other.
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Originally Posted by mpuzach
Buy one - it's definitely worth the money. It does a great job (works MUCH better than a leaf blower) and it's built like a tank.
There's 746 watts in one Horsepower rating 746x8= 5968 watts divide that by the applied voltage and you will get the operating amps not accounting for any power factors such as 3 phase anyway 5968 /120=46.25 amps that would be the power needed for an 8 HP motor ohms law or check the ugly's electrical handbook.
That would be correct. It take more than 19 amps to run an eight horsepower motor or two 4 HP motors. I think it is a great unit I just don't understand their advertising.
