Smell when hitting it
Old May 24, 2013 | 09:05 PM
Kvothe's Avatar
Kvothe
This would have been much funnier in OT.
Old May 25, 2013 | 01:29 AM
hopeman's Avatar
hopeman
Maybe you should mke sure you bath her first
Old May 25, 2013 | 05:18 AM
Don-Vette's Avatar
Don-Vette
The only thing I smell after hitting it is burnt rubber!!!
Old May 25, 2013 | 05:44 AM
brettbolt's Avatar
brettbolt
Default Its the battery
I had the exact same problem with my '08. It turned out to be a sulfated battery. When I accelerated to pass on the highway I would smell sulfur dioxide (rotten egg smell). At high speeds there is enough air pressure to force leaked air from the battery into the cabin.
I replaced the battery and the smell was gone!
BTW, I just bought a new '13 Grand Sport today. Will post photos and more later.
Old May 25, 2013 | 12:27 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by BeyondMyCapacity
I think hydrocarbon.... I dont know what open loop means?
Under normal operation, the car looks at oxygen sensor data to determine how rich / lean engine is running. It adjusts fuel injector pulse width to keep with a specified air fuel ratio. At wide open throttle, it does not look at O2 sensor. It uses tables to control fuel injectors. Exhaust smell changes under that condition.
As evrose said, I rather enjoy the smell .
Old May 25, 2013 | 12:35 PM
MLCRookie's Avatar
MLCRookie
Originally Posted by michaelinmech
If you stop, she'll probably be more pleasingly fragrant to you
I thought the same thing...but when I say it out loud I seem to get scolded...
Old May 25, 2013 | 04:08 PM
idaband's Avatar
idaband
I get the exhaust smell in cabin when wide open too. y does the smell enter the cabin though? y not all go out the pipes?
Old May 25, 2013 | 09:28 PM
Tonylmiller's Avatar
Tonylmiller
Today it hit it as hard as I will ever hit it, and never smelled a thing. I was doing laps around Talladega with a top speed of 152 mph.
