alignment recommendations
Old May 24, 2013 | 09:43 PM
hihoSilver's Avatar
hihoSilver
Default alignment recommendations
Ive done searches and got different info. I noticed my GS rears are worn on the outside, but the inside half are like damn near brand new. I have 17K miles. Is this type of wear the norm with the factory alignment specs? For people that are having their alignment set to different specs....can you post the specs that will get the most mileage? Im a daily driver that just cruises and has fun with the power but definitely don't need track like alignment. Im replacing the fronts with the Firestone rflats. Before I replace the rears, I would like to get the alignment figured out.
thanks
Old May 24, 2013 | 09:52 PM
RicK T's Avatar
RicK T
Originally Posted by hihoSilver
I noticed my GS rears are worn on the outside, but the inside half are like damn near brand new. ....can you post the specs that will get the most mileage? Im a daily driver that just cruises and has fun with the power but definitely don't need track like alignment. Before I replace the rears, I would like to get the alignment figured out.
thanks
Outside edge wear is pretty unusual I believe.
I think you should get the new front and rear tires on THEN get an alignment.
Most here seem very happy with the Pfadt Pure Street alignment for decent performance and tire wear. BUT notice that, unlike the factory specs, there is NO RANGE of specs for the Pfadt settings.....they are intended to EXACT.....NO plus/minus. That is what makes them work.
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Old May 24, 2013 | 09:54 PM
michaelinmech's Avatar
michaelinmech
Align using - PFADT Street Alignment Specs
Old May 24, 2013 | 10:13 PM
phileaglesfan's Avatar
phileaglesfan
GM specs are good if they are in the center of the tolerance. I have about 1500 miles on this alignment and no abnormal wear. If you got 17k on the OEM rear tires then your alignment is pretty good.
Old May 25, 2013 | 02:41 PM
nhisfan's Avatar
nhisfan
17K out of original GS tires? This must be some kind of record...
A friend of mine just had to replace both fronts at a little over 7K.
A check of his alignment found it to be way off - all 4 corners.
I decided to have mine checked (also around 7K) and all 4 of my corners were out as well.
My tire wear is a little better than his, but if I see 10 or 12K I'm going to be surprised.
And btw - my car is a sunny sundays, never been hammered, cruiser, too...
Like has been stated before - Pfadt 'street performance' settings are the way to go...
geo
Old May 26, 2013 | 01:28 PM
hihoSilver's Avatar
hihoSilver
thanks guys.....I have 17K. It weird. Its almost like they still had a little tread on them at 15.5k and then they were gone. Hell, If I would have swapped the backs (same direction) at 9K, They might still have a little left. I was going to go with the Michelin, but I think im going to try the firestone RF this time. I really noticed this spring that the tread was getting low when I was skiing when it rain. The hydroplaning was never an issue until now. Ive always had rears wear in the middle. It was strange to see outside wear. Also, I had a free alignment when it was pulling to the right a little, so who knows how GM Vandergriff in Arlington did? Ive been unhappy with them since my service guy for 10 years left.
Old May 26, 2013 | 08:41 PM
jwf's Avatar
jwf
I don't know if it's normal or not, but after reading about tire wear I bought a tread depth gage and measured my tires. I have about 4500 miles on my GS tires and measured the inside, center, and outside tread depth on all four. On the front both tire measured 7/32 all the way across, but on the rears both tire measured 7/32 on the inside and. Center treads but 5/32 on the outside. So I guess my question is, should I be thinking about getting an alignment done?
Old May 26, 2013 | 08:54 PM
R50THC5's Avatar
R50THC5
At 700 miles I took it to IPS motorsports here in Columbus and had Pfadt Pure Street alignment done..
Old Aug 9, 2013 | 08:51 AM
7-11vette's Avatar
7-11vette
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
2016 C2 of Year Finalist
Thanks for all the info. Going to bowling green next year don't need tire problems.
Old Aug 9, 2013 | 11:55 AM
JoesC5's Avatar
JoesC5
I see you have a GS thus you don't have a very large selection of tires to choose from. I went with the Bridgestone RE050A run flats and they are wearing great(and went with the Pfadt "performance street" alignment with toe set at zero(0).
Old Aug 9, 2013 | 02:51 PM
phileaglesfan
Goodyear's are crap anyway. I have 12k miles with the center of GM specs on my Super Sports and I'm just hitting 7/32 on the rears.
Old Aug 9, 2013 | 03:45 PM
c6vette142dude's Avatar
c6vette142dude
Get a 4 wheel alignment done.
To alignment recommendations
