Changing Dome lights??? Help
Old Jun 5, 2013 | 06:48 PM
Jonesy12's Avatar
Jonesy12
Cruising
Default Changing Dome lights??? Help
I have a 2013 GS and I bought LEDs for the dome lights.. I am having a hard time taking out the stock bulbs because the housings they are in are deep and narrow. I can't get my fingers in enough to pull out the bulbs to replace them...
Anyone know a tool or know a way that'll work?
Thanks!
Old Jun 5, 2013 | 07:03 PM
Slider-01's Avatar
Slider-01
Are you referring to the bulbs in the mirror?
If so, get a small cable tie and slip it over the bulb toward the back, tighten it and pull; comes out fairly easy then. That's how I got mine out. Some also use fishing line.
Old Jun 5, 2013 | 09:03 PM
Jonesy12's Avatar
Jonesy12
Cruising
You are the man! Thank you.. Didn't think of that
Old Jun 5, 2013 | 09:05 PM
jsucraig's Avatar
jsucraig
floss
Slider-01's Avatar
Slider-01
As they say; that's what this forum is all about.
Glad you got it.
V/R
Slider
Old Jun 6, 2013 | 10:12 AM
Jonesy12's Avatar
Jonesy12
Cruising
Well now I have the way to do it, But i tried with string last night for a solid 30 minutes and struggled... Just make a loop with it and put it around it and pull? What worked best for you guys as far as making a loop and putting it around so it stays?
Thank you
Old Jun 6, 2013 | 10:47 AM
Jonesy12's Avatar
Jonesy12
Cruising
Just tried floss too... im making a loop and everything its just impossible to pull and keep the string or floss from not just pulling off from the bulb.. they've never been removed before so they are in there tight.
Old Jun 6, 2013 | 10:58 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I used the plastic zip ties. It takes some patience but they will come out.
Old Jun 6, 2013 | 11:06 AM
vet55's Avatar
vet55
Zip tie is a great idea!
Old Jun 6, 2013 | 12:23 PM
Jonesy12's Avatar
Jonesy12
Cruising
I guess I'll have to try the zip tie way too.. I've had a ton of patience, but it gets frustrating when you realize that the design wasn't meant for changing bulbs that's for sure!
Old Jun 10, 2013 | 05:36 PM
Jonesy12's Avatar
Jonesy12
Cruising
Just in case some people run into this problem too.. try duck tape.. cut them in thin strips, wrap it around the bulb let it sit for a minute and get a grip and pull hard.. finally worked for me
Old Jun 10, 2013 | 05:46 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
These I tried everything and then tried these. You can grab the bulbs no problem and they won't break. I've done my car, my buddy's, and my trailblazer ss and never broke the bulb. Slide it to the larger position and just use lite pressure.
Old Jun 10, 2013 | 06:03 PM
swissguy's Avatar
swissguy
Leatherman Tool with electric tape around the pliers.
Old Jun 10, 2013 | 07:09 PM
Biggie G's Avatar
Biggie G
i used needle nose pliers and gently wiggled them out
Old Jun 11, 2013 | 08:04 AM
IrishSpuds's Avatar
IrishSpuds
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Floss - long piece with wide loop in the MIDDLE, then use a toothpick or something thin to push over the bulb. Tighten slowly ONLY when loop is topmost at the narrowest point (bulb base) slowly tug - you may need a couple of yanks and it will drop to the cup holder. Take your time, it is worth it. I get compliments on my LEDs!
Old Jan 10, 2015 | 09:26 PM
godzilladude's Avatar
godzilladude
I just now did the zip ties, worked great. Taking the mirror loose first was also helpful, makes it easier to get an angle.
I love this forum!
Old Jan 11, 2015 | 07:15 PM
BROCKYJACK's Avatar
BROCKYJACK
I tried the fishing line loops, needle nose vise grips and finally gave up after breaking one and took the mirror off. That makes it so much easier. 45 degree turn and mirror releases from the base. Makes it so much easier. Would have saved some back pain from the twisting. Glad you finally got it though.
To Changing Dome lights??? Help
