Battery level...Is this normal?
Old Jun 23, 2013 | 05:59 PM
cedp83's Avatar
cedp83
Default Battery level...Is this normal?
I just noticed this today and I was wondering if this is normal....
While I was stopped waiting at a red light I noticed my battery level voltage under 13... (radio on and a/c running )
while driving it goes back to 14, 14.5...
Is this normal?
Is my battery dying? (1 yr old)
Alternator going bad?
Old Jun 23, 2013 | 06:01 PM
LS WON's Avatar
LS WON
Is this normal?
Old Jun 23, 2013 | 06:46 PM
Mad*Max's Avatar
Mad*Max
whether this is normal or not my car does the exact same thing for the last 3 years (at least) that I have noticed
Old Jun 23, 2013 | 06:56 PM
EvanD's Avatar
EvanD
CF Community Team
Mine never goes below about 13.5V
Old Jun 23, 2013 | 07:11 PM
RnLi's Avatar
RnLi
My OEM battery is on 5 years. The car is a garage queen and I use a battery maintainer on occasion (when going on vacations, etc.). I have never witnessed my volt gage under 14.......including at night with lights, a/c and radio operating.
Old Jun 23, 2013 | 07:15 PM
LS WON's Avatar
LS WON
Mine is original 2005 battery and it does drop into the 13 range. Before it went as low as 12.9 but for the most part is between 13 to 14.5.
Old Jun 23, 2013 | 07:26 PM
Mad*Max's Avatar
Mad*Max
mine goes down to 12v when stopped at a light (mine is auto) with the a/c on as the engine fan is on continuously and my suspicion is that it draws a lot of power
Old Jun 23, 2013 | 07:29 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Have you checked the water level in the battery ? The factory unit is not a sealed unit. The caps do come off so you can add distilled water.
Old Jun 23, 2013 | 07:30 PM
hdkeno's Avatar
hdkeno
My 06 has a new delco battery in it. Usually is at 4.2-4.5 but i did see it momentarily drop to 13.0-13.2 at idle everything on and ac
Old Jun 23, 2013 | 07:38 PM
Pinky...'s Avatar
Pinky...
Honestly, this is not an accurate way to really gauge performance of the Alternator and Battery. You need to first verify the battery is fully charged and is a known good battery. Then you would need to load test the alternator to see if it is putting out proper voltage under load.
Old Jun 23, 2013 | 07:44 PM
Mad*Max's Avatar
Mad*Max
I put a new OEM battery 12 months ago and as I mentioned my car has been doing both before and after the battery change
Old Jun 23, 2013 | 07:46 PM
VET4LES's Avatar
VET4LES
Its normal. Put the battery reading on your DIC and get an accurate reading.
Old Jun 23, 2013 | 07:47 PM
LS WON's Avatar
LS WON
tHIS Is true I have done this.
Old Jun 23, 2013 | 07:59 PM
c54u's Avatar
c54u
Is this normal?
Mine is a 2007 and it did the same thing as yours a few years ago. I replaced the serpentine belt with a Goodyear Gatorback and presto the voltage stayed in the high 12's at idle and high 14's driving.
I would check the tensioner, and belt....easy stuff first. The belt was only 25 bucks and takes 5 minutes to put on.
Old Jun 23, 2013 | 08:05 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2009 has 60k miles and the battery was replaced just as a precaution, a year ago.
The voltage displayed on the meter or on the DIC has always varied considerably; depending on electrical loads, rpm, temperature, and probably several other items I'm not aware of.
Old Jun 23, 2013 | 08:12 PM
dvilin's Avatar
dvilin
Mine has never gone below 13.5.
Old Jun 23, 2013 | 08:21 PM
Rogers 07's Avatar
Rogers 07
This is normal, at idle on a warm day when the electric cooling fans come on, along with the AC etc, it will pull the voltage down towards 12. To check, just rev the engine a little bit to 1000 RPMs or so and the Voltage should go back up to 13+ Volts !!
To Battery level...Is this normal?
Old Jun 23, 2013 | 08:34 PM
cedp83's Avatar
cedp83
ill check the water level first...how do you know a tensioner is bad??? I can replace the belt..no problem...
BTW the battery is a Napa legend 75 (POS???)...
and the problem behind this is...my Kenwood headunit "senses" the voltage drop and goes into "safe or protection mode" so no more radio...
maybe I need a yellow top???
Old Jun 23, 2013 | 09:09 PM
c54u's Avatar
c54u
To check the tensioner
With the belt off the tensioner, spin the tensioner pulley and see that it spins freely. Put the socket wrench back on the tensioner that you used to remove the belt and move the tensioner back and forth to make sure that it moves freely back and forth. There should be smooth resistance when moving the tensioner back and forth.
Old Jun 23, 2013 | 09:11 PM
VET4LES's Avatar
VET4LES
The yellow top could be just what you need due to your sound system. Check out the Optima web page and see what they say about it. The yellow top is for deep discharge use.
