Battery level...Is this normal?
Old Jul 3, 2013 | 01:22 PM
  #41
vig1116's Avatar
vig1116
Originally Posted by redrckt97
Steve R - I think the auto/man issue is idle speed -- my A4 hot idle IN gear is only about 500rpm -- that combined with fans running is the only time my voltage has dropped below 13.
I didn't see his response to me till now. I know when I had a M6 i hardly held the brake at a light and i was in neutral so the idle is higher RPM and battery lever mostly normal. In an Auto, you're still in gear and brakes are on and the idle RPM's are lower, therefore battery strained a little bit more..... Steve R, can you honestly say in an auto tranny at a light your battery doesn't go down? and in a manual in neutral at a light with no brakes on the battery dips like an auto?
