Fob problem
Old Jun 23, 2013 | 10:16 PM
808c6's Avatar
808c6
Default Fob problem
I have had a few incentences with the fob not working. It didn't open the door and when the door open, it shown no fob detected? What is going on? Sometime it just work fine? It is very frustrating not knowing if the next will work or not. Please help.
Old Jun 23, 2013 | 10:22 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
>> FOB not detected checklist <<
Elmer
Old Jun 23, 2013 | 10:41 PM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
That's what mine started doing when the Fob battery needed to be replaced.
Old Jun 23, 2013 | 11:10 PM
Vette_DD's Avatar
Vette_DD
What year C6 do you have?
Are you aware that new fob batteries are approximately 2 for $5?
Are you also aware that GM says average fob battery life is about 3 years?
Maybe you're making something difficult out of this when it doesn't need to be.
CO Lightfoot's Avatar
CO Lightfoot
Your C6 is a 2008?
Get new fob batteries!
But first read this: http://forums.corvetteforum.com/c6-c...ement-diy.html
In the meantime, next time you get "No FOB Detected", use the glovebox slot:
This should work even with a dead battery in the fob.
Old Jun 23, 2013 | 11:21 PM
CO Lightfoot
Also, not trying to insult you, but do you know how to use the metal key?
Once you've opened the hatch/trunk, look on the left side for 2 pull-tabs... one opens the driver's door, the other opens the fuel door.
Also, lots of owners hide a spare key under the car. It's cheap insurance, in case you lock the fob in the car (easier than you think).
You can get a spare key made at most key shops. Under $10. Tell 'em to use key blank B-106 (same as a Saturn key).
Old Jun 24, 2013 | 01:25 AM
808c6's Avatar
808c6
This is my 1st vette, I don't know how to use the key and the glove box until for all your help guys. Thank you you all. I will try to replace the fob battery with the link.
Old Jun 24, 2013 | 03:52 AM
808c6's Avatar
808c6
Where can we purchase another fob for back up beside the stealership ?
Old Jun 24, 2013 | 09:43 AM
eboggs_jkvl
Moderator emeritus
How many do you have?
If you have 2, then the third will add using the short program.
If you have 1, then you need to use the long program to make the FOBs #1 & #2 to maintain "memory functions" Key FOB designated #3, by the car, will not function for "Memory" but it will function to operate the car it just won't remember the presets that #1 & 2 will.
>>C6 Fob Programming and Glove Box Slot Testing Procedures<<
Elmer
Old Jun 24, 2013 | 11:37 AM
stingraynick75's Avatar
stingraynick75
I recently had a no FOB detected issue, found out the car battery posts were corroded.
Old Jun 24, 2013 | 01:41 PM
808c6's Avatar
808c6
My #1 fob got washed 2 weeks ago and I broke the cover and the small little tap, it doesn't close tight. Do someone sell just the cover?
Old Jun 24, 2013 | 03:57 PM
CO Lightfoot
I haven't found a replacement case -- yet. They are available for other fobs (search ebaymotors for "fob case").
For a new fob, shop around for best price. I'd start at gmpartshouse.com & partstaxi.com.
Or on-the-cheap, a simple cover might hold your fob together. (Much better than duct tape. )
http://www.thejacketstore.com/servle...tte/Categories
Also not slippery, so less likely to drop 'em. And different colors for fob 1 & 2. And bright colors, so easier to see 'em & not get misplaced.
These definitely fit the C6 fob with integral key. Not sure if the earlier C6 fob (with separate key) is the same size.
Related thread: http://forums.corvetteforum.com/c6-c...d-key-fob.html
Old Jun 25, 2013 | 01:47 AM
808c6's Avatar
808c6
Thanks everyone for the help. You guys are awesome.
To Fob problem
