Slime question
Old Jun 25, 2013 | 11:14 AM
xgto's Avatar
xgto
Default Slime question
If you carry a portable compressor , do you need the Slime squueze bottle or the pressurized bottle. just getting prepared for my next set of tires soon that will be non- runflats.
Old Jun 25, 2013 | 11:17 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
If you are planning on non-run flats, I would suggest that you get a plug kit and stay away from the slim. I understand that one it will screw up your pressure sensors and most tire shops don't want to mess with the tires that have had it used or the charge a premium for the work.
Old Jun 25, 2013 | 11:35 AM
xgto's Avatar
xgto
Yes already have the Dynaplug Kit.
Old Jun 25, 2013 | 11:45 AM
Keith N's Avatar
Keith N
I always carry a portable air compressor, a small jack, torque wrench and at least one bottle of Slime at all times since I have non-run flat tires. Slime doesn't effect or ruin the tire sensors. It is intended to be a temporary fix to get the tire repaired or replaced.
Slime has saved my Corvette friends and myself several times while picking up nails or screws on the road. The stuff works!
Old Jun 25, 2013 | 11:55 AM
PatriotZ's Avatar
PatriotZ
Veteran: Marine Corps
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
I agree that slime works.....but make sure to clean it carefully and soon ....as mentioned it messes up sensors and can pit the wheels.....
Old Jun 25, 2013 | 12:25 PM
xgto's Avatar
xgto
Yes but is best to get the Squeeze Slime or the pressurized slime ?
To Slime question
