Is there really any utility to it in a street car? I know it's supposed to run cooler, and the expansion with heat/contraction with cold isn't nearly as dramatic with air (which is an issue for winter/summer tire pressures in our wide tires), but does it really do any noticeable good? The Space Shuttle had nitrogen in its tires (probably where the fad got started), but since it operated in a vacuum with extreme temperature differentials, it was necessary.
We just bought a '13 Cadillac ATS and nitrogen was a dealer "installed" option for $85. I declined it. The ATS is a great car, BTW ... stays on the road at least as good as the Vette. And the 3.6 V6 is 321 HP ... not bad for a family car that only weighs a couple hundred pounds more than a Vette.
This has no doubt been discussed here before, but I've only been back in the fold for a couple of weeks.
I keep a nitrogen bottle in my garage just for the tires in all my cars. I am a believer. With the temp swings in Wisconsin, my pressures are more stable between seasons.
The real culprit is water vapour not the gas. Both oxygen and nitrogen behave as "ideal" gasses and the difference in molecule size is trivial.
If the shop that fills the tires has a decent air dryer on their compressor this should be virtually as good as nitrogen from a bottle which completely dry.
If you live in a humid area and fill the tires from a compressor without an air dryer you will get a fair amount of water vapour in the tire. When the tire cools some of the vapour will condense occupying a significantly smaller volume and causing a significant drop in pressure.
There are many threads on this topic and they end up getting quite long with no definitive conclusion. The guys who use Nitrogen will tell you about all the benefits of the larger molecules, etc... The guys who don't use it will say it's all just snake-oil and a waste of money.
The bottom line is you should do what you think is best. Many people spend thousands of dollars trying to maximize the performance of these cars. Some modifications or "improvements" work, others do not.
I for one, put the Nitrogen in my tires. I think it costs me about $40 when I had my tires mounted. Did I waste that money? Maybe. Do I feel a little better knowing its in there? Yes. But I look at it this way, if there is even the slightest chance it is better, hell, I can afford $40. I have this in the same book as a decal or maybe chrome valve-stem caps that someone puts on their car because they like it.
If you can afford a Corvette, chances are you can spend, $20, $40 or $80 to have your tires filed with Nitrogen. Bottom line, do what you think is best for you and your car.
Spot on. Ambient air is ~80% nitrogen anyway. If anyone really thinks removing the 20% that's oxygen, which is almost the same size atom as nitrogen, is doing any good is being scammed. And, unless the tire shop pulls a vacuum on the tire after it's mounted and before it's filled with nitrogen (they don't), it doesn't just have nitrogen in it anyway.
OK so lets see. Normal air is about 21%O2 and 78% N. The O2 leaks out but the N does not due to atom size. So when I drive for awhile the O2 leaks out leaving only N. so I drop my tire pressure and now head to the local air pump or use the one in my garage. So close to 100% of what is in my tire is now N (because the O2 has leaked out). I now top off the tire with compressed air so now the O2 is about 4%now in my tire (the nitrogen stayed in the O2 leaked out. I go through this again and now I top up arain and see the O2 is less then 1% of the total tire volume. I do it one more time and I find I have a trace amount. Same as the bottle the dealer sold me. Air for me I dont mind pumping 3 times, and If I ever do go low with 98% nitrogen and am on a long road trip im in trouble if it matters to me.
With the air pressure visible on the DIC I just use air and check the DIC about once a month when I first start up, and adjust as necessary... Maybe twice a year as the seasons change.
Thanks for the ATS input, we just rented a CTS 4 for our West Coast road trip and loved it, put 2500 miles on it in 2 weeks. My lease is up soon on my DD and I was considering an ATS, will have to check it out!
Here's a Popular Mechanics review on the subject. My conclusion: It's better than using straight air but probably not worth the cost if you have to buy it.
it's ONLY TRUE BENEFIT is that is it drier. It will not cause chrome wheels to pit internally and cause crazy slow leaks. but once again it HAS TO BE PURE NITROGEN or it does NOTHING AT ALL.
