Need help with OEM Navigation Position Arrow
Jim,
The car is a 2012 GS 1LT. I installed an OEM nav system on the car (an oem system from a 2012 as well) after having the car for ~ 5 months. Car had 3,000 miles at time of installation and now has 6,000 miles. After installation of the nav system, I had the dealer re-flash the car in order to deactivate the anti-theft on the nav. After having this done, the Nav worked perfect. The nav position arrow would "rotate" as it should and track my cars movement and position as it should. Then after a few days, it just stopped. I don't know what happened. Now the arrow will not rotate. As I mentioned before, the arrow will move backwards, sideways.
There are no other issues with the car. No error messages, etc. No power issues. I have not done any other mods to the car other than the nav installation. I have no other issues with the nav at all. Everything else works as it should including the usb/aux.
I have spoken with a couple of guys that installed oem navs onto their cars and they did not have any issues, so I figured it would work with mine.
Thanks.
John
I've tried to reload, reset, recalibrate, etc.
The gps location arrow shows what road I am traveling on. The arrow will move (as I drive along) the road.The arrow shows my location on the map.
What the arrow does not do (And it should, because it did this when the system was new):
The arrow will not change the pointing orientation as I change direction (e.i. north, south, east, west). What this means is that the arrow will travel sideways, backwards, etc. all the while pointing north continually. It seems as though the arrow does not know the nose of the car has changed north/south/east/west. Sorta like the car is traveling sideways, backwards and such down the road.
The position of the arrow is stuck in a north position, regardless of cars actual traveling direction. Regardless of changing between the two functions (GPS arrow moving / Map moving) the arrow orientation is STUCK.
Jim,
Thanks.
John
If you can find the supplier GM uses in your area to get their entertainment modules repaired you might be able to pull the unit yourself and send it to them for repair. In upstate NY all the dealers send their stuff to United Radio in Syracuse.
Here is their web info if you are interested:
http://unitedradio.com/automotive/ It might be worth calling them and seeing what they might be able to do for you.
Bill
Thanks for the info.
Bill and I are looking at different possible problems.
I'm wondering if the Nav isn't being told the car's heading, so it can't rotate the arrow. Bill is thinking that the Nav is getting the heading information but can't process it.
Since you aren't having any other problems with the AH or other systems, that lends a bit credence to the idea of an internal problem in the Nav.
Any other thoughts or information?
When I'm in a big underground parking garage where you would not expect to get a GPS signal, and the "No GPS" flag is indeed showing on the factory Nav, it still knows our direction of travel and can approximately calculate our position by Dead Reckoning- speed/time/direction. As I drive 'round and 'round, searching desperately for a parking spot where our doors won't get dinged, the Nav screen shows us doing all the turns.
Also, when I drive up our ~50 yards driveway, the nav shows our proper movement and direction. If I do slight S-turns up the driveway, the system shows them also. If I stop at the street and back down the driveway and do slight turns, the Nav shows everything except it does not reverse our direction, it knows that we are still pointed up toward the street even though we are traveling in the opposite direction.
Based on that, I've come to believe there is some kind of heading input into the Nav, that does not rely on the GPS signal. Whether it is the same heading info that Active Handling uses, or something else, I'm not sure. So I think it leaves the OP's problem open to two possibilities- Nav isn't getting the heading input, or it is getting the heading input but can't process it.
"I don't understand all I know about this stuff."
Back when I was a young copilot on UAL, the Captain and I were discussing some technical issue about the airplane; he used that line and it stuck with me. I thought it was both funny and profound at the same time, and my opinion hasn't changed over the last 30 years.
I wish I could remember his name, virtually all of those guys were great pilots and great people.
"I don't understand..."
