Diff Oil?
Old Aug 8, 2013 | 09:40 AM
AV8TOR536's Avatar
AV8TOR536
Default Diff Oil?
I recently changed my differential oil to Castrol Syntrax 75w90 for
limited slip diff,if my 05 sits for a couple of days it still growls and binds
for the first half block when i pull out of my driveway then its fine, should I add more
friction modifier?
Old Aug 8, 2013 | 09:49 AM
z51vett's Avatar
z51vett
friction modifier?
I would go back to the latest fluid from GM no additive needed I think.
GM had a lot of problems and seems to finally fixed it last 2 z06's have proved to be very quiet.
z51vett
Doug
Old Aug 8, 2013 | 10:06 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
The Castrol website does not say anything about this product having the necessary supplement. You will probably have to add the posi supplement. Don't forget the necessary figure eights in a parking lot to fully integrate it.
Old Aug 8, 2013 | 12:38 PM
Jimbo 89's Avatar
Jimbo 89
I used the Amsoil with the slip-lock additive. No noise here.
Old Aug 8, 2013 | 12:56 PM
GOLD72's Avatar
GOLD72
AMSOIL Severe Gear has stopped chatter on two of my vettes. It has additive in it but if your car has relatively severe chatter, extra additive added separately is recommended.
GOLD72's Avatar
GOLD72
z51vett
Doug
Fixed starting MY2009 with the introduction of DEXRON LS as factory fill.
Old Aug 8, 2013 | 09:26 PM
AV8TOR536's Avatar
AV8TOR536
I guess I will add a small bottle of FM and see
what happens.
I will let you all know if it does anything.
Old Aug 8, 2013 | 09:38 PM
NormWild's Avatar
NormWild
+1, great stuff.
Old Aug 8, 2013 | 09:54 PM
Jim2003's Avatar
Jim2003
I haven't changed my C6 deff fluid yet. But I changed my C5 with GM fluid and it solved all the noise, chattering, etc. I see no reason to use another brand.
Old Aug 8, 2013 | 10:54 PM
Gering's Avatar
Gering
Tolero Apto Victum
z51vett
Doug
Old Aug 9, 2013 | 12:59 AM
AimHigh's Avatar
AimHigh
Redline synthetic is really good as well...
Old Aug 9, 2013 | 08:58 AM
truckplay's Avatar
truckplay
I would try some LS additive first and do 5-10 figure eights. then make that call. I tried the BG JUNK in mine and had the CHATTER but no noise. switched to RP and it worked great.
the BG junk in my M6 was hard to shift when cold, I also drained it and used RP
good luck
Old Aug 9, 2013 | 09:20 AM
vig1116's Avatar
vig1116
The problem with just adding additive is that (I think I read) too much can cause the seals to deteriorate. If it still is making noise, if it were me, I would change it out again and put in Amsoil severe gear WITH the 4oz additive. I just changed mine to amsoil about 2 months ago and all is good....
Old Aug 10, 2013 | 08:06 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As indicated above, lots use this with good results:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
I use the Severe Gear 75w90 with no extra additive in my 02 Z06 at the track.
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 10, 2013 | 08:10 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
z51vett
Doug
Mine was changed to the new GM stuff when it first came out and not a peep since. The new GM fluid requires no additive and has finally fixed the 50 year old issue.
Old Aug 10, 2013 | 09:12 AM
MikeERWNC's Avatar
MikeERWNC
I have tried other oil brands...
So far the GM LS DexRon is the best.
You will know for sure in 10K miles.
Old Aug 10, 2013 | 09:34 AM
Mad*Max's Avatar
Mad*Max
friction modifier?
use the new GM fluid which does not require the additive and do the figure 8's
To Diff Oil?
Old Aug 10, 2013 | 10:40 AM
LMB-C6's Avatar
LMB-C6
what happens.
If the stuff doesn't have the FM in it then that's the source of your problem.
I put the new GM fluid in mine last year when it just started making noise one day. Not a peep since. Funny how it was quiet for years and then just started doing it out of the blue. I wonder if the FM they put in at the factory just wears out with time.
Old Aug 10, 2013 | 11:34 AM
Bandit1's Avatar
Bandit1
Yep ..Me too.
Old Aug 10, 2013 | 03:25 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
For whatever reason, the GM differentials in C6 Vettes & later year Caddys (not sure about C5's or earlier) are sensitive to the % of limited slip friction modifier in the gear oil. IMHO, best to stick with the Dexron LS Gear Oil, 75W-90, GM p/n 88862624. This is the later formulation that GM came out with after problems surfaced with clutch slippage in early C6 diffs. The bit about "figure 8's" is to insure that the new fluid is properly driven into the clutch packs. The TSB calls for 8-10 slow speed figure 8's after the fluid is changed.
