I just registered with this forum, because I'm about to purchase a 2005 corvette. After much research I've found many issues that are of concern! I believe the recall on the active handling system is a fairly easy fix, but the targa top becoming detached while driving is of great concern (even after being serviced...supposedly)! How many vettes in this year are affected by the fuse block overheating and causing the headlights to go off?? Any help is greatly appreciated! Thanks in advance and looking forward to being a part of the family!!
Bought my 05 Z-51 Vert 6spd manual 6 months ago and it has been a joy to drive!!! Granted, only had 9k on the odometer when I purchased it, but it runs flawless and problem free. There are others on here that would try to shy you away from an 05 but I'd say bull****.. I read of more troubles, problems & issues with the later model vettes than let's say the 05's or 06's for that matter. Any model year can have issues, There is nothing IMO to shy you away from an 05 if that's your decision. Things to check? harmonic balancer, battery, tires etc etc. the common stuff to check. Not sure about targa tops since mine is a convertible. Drive it, tranny check too, all the important stuff...Get a carfax & so forth The 400hp LS2 is more than enough power for me!! Good luck!!!!!!
I had a 2005 triple black convertible with NO problems whatsoever. I sold it later to get a C6 Z06. I missed that tripleblack convertible so much that I ended up selling the Z06 and getting a 2008 triple black convertible. I love the car.
Never heard of fuse block overheating. My 05 has been trouble free (except for HB) for the 3 years I've had it. I had the top replaced last year. The old one was not coming apart but while it was at the dealer for harmonic balancer they put a new top on it. I've never read about a replaced top after recall being defective either.
Thanks to all of you for the quick replies!! I just came across the fuse block issue today as I was digging deeper into any possible electrical issues. What's with the harmonic balancer?? I haven't heard anything on this.
This is a complaint I found on carcomplaints.com and there are many more identical to this...."Headlamps quit working while driving at night. Both headlamps did not turn on and I had to drive with the fog lights. I checked the relay and fuses which were all okay. This morning, they did work. I've researched other owner forums of which this incident has happened from a bad ground from an overheated fuse box in the engine compartment, with owners driving at night and driving lights going out inexplicably, which could lead to serious injury.
there are several threads on the harmonic balancer pulley problem on the forum here, just do a search on them... some have video as well to assist you. It wasn't just the 05's that had this issue
If that headlight thing was a major concern this would be the place you would read about it. I saw an article about it on yahoo news I think but not here.
Thanks Jimmy52 and EvRose! I'm probably looking too deep into this. I just want to be prepared and make the smartest decision I can. Most everything I've read says the C6 is by far the best sports car out there for what you have to invest!! I'm very excited and look forward to my venture. The car I'm interested in only has 15k so I hope it wouldn't have any HB issues?! Thanks again!
An 05 with ONLY 15k on the odometer??? I think you'll be fine.. Good luck & don't forget to post up pics if you get it!!
Its a good tough car. Engine nearly bullet proof. On an 05 Im sure any recall work or possible problems have been taken care of by now. I bought mine before I joined this forum. Its been the best car Ive had. I read about all potential problems after I bought it and still have no regrets.
If it's a manual tranny, make sure it got the BCM reflash to eliminate DBS. Or get the SCL bypass from Corvettes of Houston. My SCL (they all will) went out after about 8 years. Enough '05's had defective lighting wiring harnesses, causing some bulbs to go out soon. A dealer probably could check if yours are ok. Mine were replaced on warranty. The harmonic balancer should def be changed if your VIN is less than 11039. This is when they improved somewhat on the bad design. Mine was replaced around year 3 on warranty.
I have never heard of the headlight fuse panel overheating in my 4 years on this forum. There have been no recall to my knowledge on this, and I'm pretty sure there would be one since it is a safety issue.
The targa top delapitating was an issue in 05-06 but if you get a GM dealer to run your VIN, they can tell you if it has been fixed, or has had any issues with recalls or TSB's.
The balancer is hit or miss on most of the C6. I have an 06 with 60K miles and no issues with any of the fore mentioned issues.
Not exactly. The lower VIN #s had a problem with the crank bolt coming loose. After that 11039 they redesigned the bolt washer with a diamond coating so it would not back out any more. The actual balancer remained the same all the way to the end of the C6 run. There have been reports of a new improved one but I've never seen evidence of it other than a different part # which means nothing.
Once again I would like to thank each and every one of you for your help!! The fuse block issue I had mentioned were incidences reported to the NHTSA and in 05 there were many, but in comparison to the amount of cars produced it is probably more than minimal. Knowing that it's pretty much unheard of here is most comforting! I'm pumped to be sporting a C6 and looking forward to chatting with you all!! This forum ROCKS!!!!
Very happy 05 owner here, the only thing that would make me look closely is the 15k miles.... might be an indication that the car sat for a long time unused, which is not necessarily a good thing.
I just had this problem last week. My headlights went out and thought it was the relay. i replace that but still no headlights. Took it to the dealer and they said that the fuse block had to be replaced. I wasn't familiar with doing the replace myself so I had them do it. I'm sure I was overcharged but all is working. I don't know the cause but I have 60k on the odometer and this was the first real problem that I've had. I have the old fuse block if anyone is interested.
