2011 GS Ongoing No-Start Issues
Old Aug 29, 2013 | 08:48 AM
ParisTNDude's Avatar
ParisTNDude
I think the battery draw down will occur in 21 days on a mechanically perfect Corvette. In that, if you don't run your car in 21 days you can expect a dead battery. So there's a current drain that is normal...just watch your alarm armed lights blink and you know that.
In past years, you could disconnect the positive battery terminal and connect a volt meter between the post and the removed battery cable and if there was a current draw, the volt meter would read 12.6 volts. With the meter connected, start pulling fuses one at a time until the volt meter reads zero. The fuse removed that caused the voltmeter to go to zero is the culprit circuit. Trouble shoot that circuit for ground faults, or short circuits and you can fix the problem. In newer cars with so many computer systems that monitor the car's systems even when it's not running, that trouble shooting tactic may not work...it's kinda "old school"?????
Old Aug 29, 2013 | 08:59 AM
vet55's Avatar
vet55
Subscribed.
Old Aug 29, 2013 | 09:18 AM
z51vett's Avatar
z51vett
You need a good electrical tech either at independent garage or at Chevy dealer. Seach your area for recommendations. Oh my 2012 z06 sits for longer than 21 days and no dead battery and it has mild to wild. Anyone check fobs battery to see if they are good. It maybe loosing communication with car causing shut down.
z51vett
Doug
Old Aug 30, 2013 | 12:10 AM
2006c6keller's Avatar
2006c6keller
Default Cheap?
Originally Posted by KABAL182
Had very similar problem with my 2011 GS vert. Im just going to cut to the chase. Two different dealers had my car for almost 30 days. The starter was replaced, wire from battery to starter and ground wire. Still had same problem. The tech finally got someone from GM that told the tech to slightly ground down the tips of the starter bolts. I was like you have to be kidding me, and thought the tech was BS me. After thinking it over it seemed plausible. The GM factory rep said in not so many words that some bolts were not up-to gm standards and might be slightly longer and cause the starter base to lift slightly off the motor causing a short and losing "ground". My car was fine after this "fix". The tech ground off less than half a thread.
Another way to solve this type of problem, add one or two flat washers to bolts, I have done this before. I guess it was cheaper to grind off the bolts than spend 20 cents or so at Lowes.
Old Aug 30, 2013 | 12:40 AM
2006c6keller
Originally Posted by Top_Fuel
It's unfortunate...but that history of replacement parts may be an indication of how dealer service departments aren't set up to handle these types of in-depth diagnostic problems. A tech generally isn't getting paid until he finds your problem. He's getting paid a limited amount of time to diagnose the issue...so if he can't track it down in in that time, he won't spend forever on it because he won't get paid for the work. This can be even worse for warranty work, which can pay a tech even less. This is where the flat-rate pay system can work against the customer's best interest. You can't blame the tech for not wanting to work for free.
I once looked at a used Z06. The thing had the PCM replaced THREE times in a couple of years. Turns out the AC evaporator drain tube was clogged...and water was dripping onto the PCM shorting it out. The last dealer to work on it unclogged the drain and fixed it for good. The first two guys who worked on it just hung the new part and sent it out the door. There's no way this car should have had to go through 3 PCMs. But the system allows this kind of stuff to happen.
It's hard to imagine a dealer throwing in the towel on it. Like I said, it may just need a fresh set of eyes at this point...or even some diagnosis from an independent shop.
I understand your frustration. At least the dealer is willing to work with you.
The reason I asked about a M2W switch is because it can cause battery drain if installed incorrectly...which obviously isn't your problem.
Top Fuel, you are giving him some very GOOD advice, I hope he listens to you. It is probably a very simple fix when you find it, the problem is to find it. There was another problem on another thread where a connector plug wire separator clip was missing on the plug wire coil connector, simple fix and it is working so far that I last read, no more stumbling.
I was a top student in electrical/mechanical nine month class in the service. Working out in the field with 45 technicians, only ten knew what they were really doing. The rest you didn't really want to follow them, they twisted, turned, etc. anything they could see or touch. It would take an accomplished repairmen to reset it up to basic specs and it would run 99% of the time. Now you know how i feel about technicians. I should be an engineer except for the higher math, that's where I failed.
TF, keep up those great tips you are giving, it could just be a loose connection, bad crimp, corrison, no connection that is dangling, etc. A very good visual and jiggling of connections, slipping connections on and off a few times, torn boot, etc. I know that you get the idea, many techs don't think like we do.
To the OP, hang in there, the previous plug connector missing part owner was about to give up. Follow him, and keep looking, someone will find the problem, it only takes one bad part or connection, etc.
I'm counting on you to hang in there, please find another shop when the current shop is exhausted. Then you lhave a chance.
Old Aug 30, 2013 | 05:05 PM
Charlie Chan's Avatar
Charlie Chan
Well, good news / bad news. The bad is that we'll never know what the problem is and I will be getting rid of my Torch Red beauty. (Man, I like that color).
The good news, I guess, is that GM is taking the car back. That's pretty much all I'm comfortable sharing at this point. I don't know any details as far as reimbursement for my car, etc., but I've been reassured that I will be taken care of. We'll see...
I'm comfortable with the attempts by the dealer to find the problem. One other dealer, and GM in their first buy-back, could not isolate this issue. Maybe an independent shop could have found something? Who knows? How much more does a person keep trying?
Thanks to all for you recommendations, tips, and well-wishes. Here's hoping I'll be posting pictures of a replacement C6 soon...
Old Aug 30, 2013 | 11:46 PM
lordofwar's Avatar
lordofwar
Originally Posted by red2012
Now you know why it was a buy back. I don't care if they gave me the car for free why would you ever get involved with a buyback no matter what they promised you. Sorry for you troubles and it seems you will have plenty. Good luck.
Old Aug 31, 2013 | 12:54 PM
AddisonD's Avatar
AddisonD
Originally Posted by Mr.Impulse
Well, good news ...
Of course you will. There are so many beauties out there to pick from.
No need to fret the past now, just enjoy the hunt for the next one!
I still hunt 'em, even though I'm set for now. But I did enjoy the hunting so much, that I just can't completely stop.
In fact, here is a torch red GS vert that I saw just a few days ago:
http://cadillachouston.sewell.com/we...on-TX/1380856/
Good Luck, and show us all the pics when you can - so we know, The End Of The Story.
Old Aug 31, 2013 | 01:26 PM
jh61408's Avatar
jh61408
Originally Posted by joec
I'd like to know how to check for a parasitic drain... had my battery go dead on my 13 g's after 5 days... I do have a mild to wild....
You need to wire the mild to wild through the seat heater fuse block, as the the original point they use is hot all the time {Exhaust Fuse}, as the module will slowly drain your battery. I have mine that way. Never have had a battery issue.
http://www.pfyc.com/supportfiles/mildtowild.pdf
----Alternate “0” Drain Installation-----
Old Aug 31, 2013 | 08:13 PM
joec's Avatar
joec
Thanks I saw that.... will be changing mine.. appreciate it ...
/jc
Old Sep 1, 2013 | 01:25 AM
AddisonD's Avatar
AddisonD
I do not claim personal expertise, but I know for sure that I have read many times, and it is in the install instructions for M2W, that if you leave the baffles open (wild setting) there is no drain.
I have let my car sit for weeks at a time due to my business and vacation travel. I have never had a low battery problem. I do leave it in wild.
That setting is the same as no fuse at all, and I cannot see how there could be a current flow if the fuse was pulled, and the circuit was thus not complete.
JH, do you disagree with what I am saying here?
Old Sep 1, 2013 | 08:32 AM
joec's Avatar
joec
I'm no expert either but I always leave it in WILD mode and have this issue with battery drain on both my 08 and now my 13 GS... Something ain't right...
Old Sep 1, 2013 | 02:04 PM
  #33
jh61408's Avatar
jh61408
Correct, It is if you leave it in the "On" mode that you will have the problem, the "Zero" drain install just eliminates the issue of forgetting to change the position from "On" to "Off". If you pull the fuse, you have it in a permanent Wild position {Off} and besides if you don't have a module to change positions so this would not apply. It's the module that has a slight drain on the battery.
Old Sep 1, 2013 | 03:58 PM
  #34
Bill Dearborn's Avatar
Bill Dearborn
Not true. I regularly let my car sit in a cold garage for more time than that and it fires right up. Longest time it spent without the battery being charged was about 5 weeks. Started right up.
If it is possible with one car it is possible with all of them.
A lot of people fall victim to the battery myth. Oh, by the way you can discharge batteries several times without hurting them in the short run. They may totally fail sooner than they should a year so later but they can take multiple discharges. I've depleted mine several times when working on the car and the battery came back.
Bill
Old Sep 1, 2013 | 05:56 PM
  #35
AddisonD's Avatar
AddisonD
Without question, something isn't right.
I just don't see that it is the M2W unless it is left in the "on" (mild) position. And the thing is, if the technician involved is chasing the wrong thing, then the real cause will remain unresolved.
Old Sep 11, 2013 | 08:49 PM
  #36
ParisTNDude
Bill
Bill, you must be right if it happened that way with yours. I know it was that way on the C5 since I traveled often for a month or more. New battery with no issues would not start the car right at 22 days. But, there are clearly some things that continue to draw battery power when the car's not in use...witness the blinking lights...lol. Anyway, I hope the OP finds the trouble in his electrical system.
