Changing diff fluid
Old Aug 23, 2013 | 08:21 AM
  #41
rcooper's Avatar
rcooper
St. Jude Donor '15
09, 57,500 miles, and have never touched it. Its perfect, from day one.
Old Aug 23, 2013 | 10:01 AM
  #42
indyspeed's Avatar
indyspeed
The first time you change most of the fluids (especially motor oil and transmission), they typically don't look good. Lots of fine metal particles. My diff actually didn't look too bad compared with my motor oil and transmission. Nonetheless, I switched my motor oil, transmission, and diff to Redline. Didn't really notice much of a differenence with the motor oil, and I just did the diff so I can't comment on that yet. But the transmission now shifts so much smoother. My Z06 use to be a bit notchy shiftting when cold, and with Redline it is totally smooth. Good stuff.
Old Aug 23, 2013 | 12:15 PM
  #43
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by MikeERWNC
That doesn't explain why the car started chattering...
The oil might still have life left in it, but if your car is chattering maybe you should replace the oil. As in my case.
I personally would rather replace the oil for 40.00 when the car gets noisy so I can drive a quiet car instead of paying 40.00 to get my oil tested and still be driving a noisy car because some lab tech said the oil was still fine.
If I had a car that was not making noise, I would still replace the oil at regular intervals just to help keep the differential somewhat clean and avoid any unneeded wear because I was too cheap to replace my fluids before they are 100% worn out.
But you keep paying the laboratory, they really like your money.
Relax.
If our car developed the chatter at any time, I would immediately have the fluid changed.
I was only trying to second ELP_JC's post that once the initial crud has been removed, then the next fill can go for a long time- if you don't have chatter. The lab results give us some idea of how long the fluid can go before it is "100% worn out."
Old Aug 23, 2013 | 12:50 PM
  #44
mophead's Avatar
mophead
Haven't seen anyone say this. When you remove the rear diff fluid it will STINK so don't worry.
After refilling be sure and do your Figure 8's in a parking lot somewhere.
Old Aug 23, 2013 | 02:09 PM
  #45
ravill's Avatar
ravill
I can't find my drain hole in my 2010 GS. I can see the fill hole, but not the drain. I'll post some pics.
Old Aug 23, 2013 | 02:50 PM
  #46
choprfgr's Avatar
choprfgr
I changed the diff fluid in my 37 zephyr rear end last year after
50 years of being half buried in the ground. Do you think I should have waited?
Old Aug 23, 2013 | 05:40 PM
  #47
LMB-C6's Avatar
LMB-C6
Should have let it be, those are 'filled for life'
Old Aug 25, 2013 | 08:42 AM
  #48
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Red,
If you do opt for the AMSOIL fluids, this is what you'll need for tranny (assuming 6 spd manual) and diff (and yes, all C6 models have limited slip diffs):
AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
Quantities would be 1 gal Torque Drive ATF, 2 qts Severe Gear 75w90, and one bottle (4 oz) of Slip Lock Additive.
Have fun in October!
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 25, 2013 | 06:26 PM
  #49
LS WON's Avatar
LS WON
Originally Posted by C66 Racing
Red,
What's the difference between using the Universal Amsoil ATF vs. AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
on a 2005 Corvette with 4 spd. auto trans?
Old Aug 26, 2013 | 08:05 PM
  #50
C66 Racing's Avatar
C66 Racing
Not too much - both are Dexron III fluids.
Dating back many years ago now, but in about 2007 I discussed these two fluids with AMSOIL's lead drive train engineer and how they were used in GM manual transmission fluid applications. Not long after that discussion, they updated their online application guide to indicate the Torque Drive ATF as their "primary" recommendation and the Universal ATF (now call Signature Series Multi-Vehicle ATF) as the "secondary" recommendation for manual transmissions.
I think the main difference is the Torque Drive ATF has no viscosity modifiers and won't shear down in viscosity despite the shear forces on the fluid in the transmission (not that the Multi-Vehicles ATF is prone to viscosity shear down either, but it does have some viscosity improvers).
I've been using the Torque Drive ATF in my T56 at the track since 2007 and recommend it for all GM Tremec applications (as AMSOIL does).
For automatics, the larger viscosity spread the viscosity improvers of the Multi-vehicle ATF may lead to AMSOIL's recommendation swapping, and for ATFs, I'd use the Signature Series Multi-Vehicle ATF (product ATFQT).
Old Aug 27, 2013 | 01:33 AM
  #51
LS WON's Avatar
LS WON
I can't remember what the bottles looked like. Certainly they don't look like the new ones I see on here. I believe there was only one type of ATF at that time which was recommended for 2005 Corvette auto. Now I see they have more choices.
