I'm wondering what the deal is on my C6 floor mats. There is no way to keep them anchored. My old C5 had "hook" to keep the mats from moving, but the C6 only has pins that are worthless. Any advice?
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
MY 07 was a change from the post to the hook type mount. Are you sure you have the right mats?
Post mount had a plastic tab underneath the mat. The tab would snap on to the post. When looking at the mats installed, you couldn't see any of the mount.
It sounds like the mats you have aren't the correct ones for your car. If you look at the carpet under the mats you should see some type of anchoring device (either a hook or a post). Your mats should have a part that fastens to the anchoring device.
