Car not setting level
http://forums.corvetteforum.com/c6-c...ing-issue.html
You could have a similiar issue with the spring adjuster, Also is the air pressure even in both front tires? you never know!
Has anyone adjusted your ride height?
Its not hard to adjust the ride height. Do a search or PM me and I will send you a couple links that show how to do it.
Also, check for the leaf springs themselves to be sure that they are not cracked or delaminated.
Keep in mind that if you raise the front left using the adjusting bolt, the rear right will be lowered and vice versa.
In other words, whatever you do to one corner, the diagonal corner will be affected as well, although not necessarily proportionally.
If all 4 are slammed, then the height on the front should be equal, and the height on the rear should be equal. If they aren't, then you will have to play with the bolts until you get the desired effect.
I had to make many tweaks before I got my car height even from side to side.
I'd do the surface first too.
The driver's side is usually a tad higher than the passenger side from what is reported on the forum regarding the C6, 1/8-3/16 in. or so.
Then take the car to a Professional shop that can measure corner weight and find out if the car is set up properly. Fender or rocker panel height has very little to do with suspension height. There are + or - tolerances for every suspension part location AND for every body part that is attached to the frame, those tolerances can "stack" and make it appear that the body is not level when the suspension is correct.
Which would you rather have, a car that looks level or a car that's properly corner weighted?
If you have any questions regarding ride height, you might want to check with your alignment shop first.
It does depend on the suspension package.. I would assume yours is an FE3, FE4, or FE5
You do measure from the ground up through the center of wheel to the bottom of wheel well.
The Front should be 27.3 in +or - 0.39 inches... This the p-height in GM's specs
The rear should be 28.2 in +or- .039 inches .. This is the R-height in GM's specs
Mine was out of spec. We changed the front spring out and it made no difference..
If anyone wants a copy of all the spec send me a message with an email address and I can send to you..
I currently have 2012 GS and it is within specs....
Hope this helps..
To the OP, mine was never "level" either, nor has any other car I have ever owned, and no matter what you do to level it will all get thrown in the wind when a fat guy like myself gets in on one side or the other.
As others have said, get it corner balanced and go drive it. A proper alignment made all the difference in the world as to how mine handled.
Some people have said you can use a level and a couple of rulers to get the same measurements, that looks like it could be done on the rear suspension but the front has some parts that get in the way and looks like you'd need to make a curved ruler. I found a used GM tool really cheap, so I just use that method.
Hope this helps..
Can someone check the 2010 or later Service Manuals, to see if this procedure is actually approved? It is not in our 2009 Manual. That book calls the trim heights (measured on the suspension) the Z and D heights.
But even if it's not in the Manual, it would be nice if GM had some numbers that would allow a quick "ball park" check. In the past, base C6 numbers from actual unmodified cars have usually shown the rear wheel arches to be about 1 1/4" to as much as 1 1/2" higher. The specs have changed from year to year, so figuring out what is correct can be confusing.
Of course, any numbers like this need to be corrected for tire tread depth, I'm guessing any GM numbers are based on new tires.
And were the numbers provided by the normal GM service group, or the racing division, or an outside racer? Trying to figure if they would apply to a normal street-driven car. In our case, a 2009 Z51.
Thanks!
Hope this helps..
PLUS or MINUS 0.39" means there is 0.78" difference allowed.
Front = 27.69" to 26.91"
Rear = 28.59" to 27.81"
This engineering document also says to measure the Z and D Heights if the P and R height are not within specs.
I tried to copy this 3 page doc to the forum but couldn't..
One thing I have noticed is that I just put new Michelins on the 2012 and it dropped the front end out of specs slightly but it's the same on both sides. Just makes the front spoiler scrape in place that it didn't with Goodyears.
