Is it possible to get 0-xx speeds higher than 60? I'm thinking it would be cool to get a time readout for 0-100 or 0-150 when running some of the mile events.
Right now there is
0-60
60-130
1/4
1/2 mile
Mile
Times
I'm just trying to get it converted of front wheels for more accurate reading
Does it also function like the OBD code readers, like your OBDlink MX, to read and clear codes, or is this just a live data feed? This is a really cool product.
x2
Thanks for the answering of my previous questions. Are these in stock for shipping if I order this week?
Hi can somebody please tell me how to update this thing.
http://www.palmerperformance.com/downloads.php
Download the firmware file from the link above (and the DashLogic Config tool if you don't have that already). Then open the DashLogic Configuration software. At the top select Tools>Firmware Upgrade and pick the DL1010U_Firmware file you just downloaded. It will finish in about 20-30 seconds and you are set.
One question I didn't see asked here, is can you make configuration changes to the module while it is plugged in and powered? Say I take my laptop in the car and ask the passenger to make adjustments. Does the new configuration download and immediately start up after it is finished?
Yes, you can make changes to it while it is connected, you only need to move the switch to "config". Once you hit save on the DashLogic software, it is instantly on there. Flip the switch back to your profile number and it will start up with your changes.
Is it possible to get a continual digital speed read out on the DIC with this?
Yes, you could put vehicle speed on the DIC as a digital number. On top of that, using the built in calculation system, you could create a calculation to show the square root of your vehicle speed if you would like
I just wanted to let those with A6's that it has full tcm support as well. So you can read trans temp, current gear etc. It's cool that even in D mode it tells you what gear you are in at all times if you choose that particular PID. So you can see what gears you are in when passing, going from a roll in Mexico etc when not in paddle mode.
I can have 4 PIDS on the HUD plus 2 more in the DIC for a total of 6 PIDS being displayed at the same time without having to route wiring and buying gauge mounts. How cool is that?! I forgot to mention, exceptional customer service too.
So you can display manual trans gear pos on the HUD?
