Trans help
Old Oct 20, 2013 | 01:30 AM
Jim Vett's Avatar
Jim Vett
6th Gear
Default Trans help
I asked this on the tech Fourm nag got a linkage response but nothing else. Does anyone know why I would lose reverse when alli did was drop the pan and change the filter and fluid. Any help would be appreciated. Reverse less. Thanks
Old Oct 20, 2013 | 06:42 AM
Don-Vette's Avatar
Don-Vette
Did you check the linkage?
Old Oct 20, 2013 | 04:49 PM
Gering's Avatar
Gering
Tolero Apto Victum
Old Oct 20, 2013 | 05:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
what's the fsm say about it? there must be a diagnostic tree or procedure to see what it might be caused by.
Old Oct 21, 2013 | 01:11 AM
cranky's Avatar
cranky
filter may be sucking air if improperly installed. also, the trans may not be full of fluid.
Old Oct 21, 2013 | 01:12 AM
cranky's Avatar
cranky
just thought of something else you can check quickly. put in reverse and see if the back up lights come on. if they do, your linkage is ok.
Old Oct 22, 2013 | 12:34 AM
Jim Vett's Avatar
Jim Vett
6th Gear
will check both when I get home, thanks to you and this fourm
To Trans help
