Brake upgrade
Old Oct 23, 2013 | 05:32 PM
awacsdavid's Avatar
awacsdavid
Default Brake upgrade
I need some help guys. I tried searching and couldn't find the answer.
My question is....
Can I upgrade to Z06 rotors and calipers on by base C6 without any modification?
Thanks!!!
Old Oct 23, 2013 | 08:30 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The Z06 brakes will fit the car with no issues.
Fitting your wheels is another question. Spacers are an inexpensive option.
Old Oct 24, 2013 | 01:02 AM
Wayne O's Avatar
Wayne O
CF Senior Member
As noted, wheel fitment will be a consideration. FWIW know you can do quite-a-few things to improve the effectiveness of your stock brakes...more aggressive pads, better solid/slotted rotors, stainless steel brake lines, stainless steel pistons, improved brake fluid, brake air ducting and a better (adjustable bias) master cylinder come to mind. Depending on how you use your car and what you're looking for in a brake "upgrade" I suggest you at least explore some options other than Z06 brakes. You might check Doug Rippie Motorsports or LG Motorsports to see what they might suggest just to compare. Good luck with whatever you decide on.
Old Oct 24, 2013 | 10:16 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
My question is....
Thanks!!!
Is this just for looks?
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 24, 2013 | 10:20 AM
franman69's Avatar
franman69
What Wayne said... I have basically done ALL the upgrades he lists and now my Z51 brakes are solid as a rock for hard threshold braking on track days. I've probably got about $1,300 in the brakes with front rotors, track pads, lines, cooling ducts and SS pistons. Did all the installs myself with my buddy who's a mechanic. All great incremental upgrades over the past two seasons, but I feel like I'm there now.
Old Oct 24, 2013 | 10:52 AM
awacsdavid's Avatar
awacsdavid
I admit....I really love the looks of the Z06 calipers. But the better braking will be nice.
awacsdavid's Avatar
awacsdavid
Awesome
Old Oct 24, 2013 | 11:30 AM
Carbotech Adam
Supporting Vendor
Awesome
Are you tracking the car?
Old Oct 24, 2013 | 11:45 AM
awacsdavid's Avatar
awacsdavid
No I am not
Old Oct 24, 2013 | 11:52 AM
Carbotech Adam
Supporting Vendor
Ok just a word of caution the brake pads for the ZO6 caliper are a lot more money than the regular caliper. They will make a nice improvement though. If you decide to go ahead with the project I will be happy to help you out with some great street pads.
Old Oct 24, 2013 | 12:01 PM
awacsdavid's Avatar
awacsdavid
I will like to keep the brake dust down. Probably don't need 3 piece pads, I can go with single pad. What kind of cost am I looking at?
NY3quartrs5-oh's Avatar
NY3quartrs5-oh
save yourself a ton of money and get the base calipers powder coated and put slotted/drilled rotors and pads... You don't track so good pads will make an improvement.... I went cheap and bought the brakemotive package for $208 and they are a perfect upgrade for me. Looks 100% better than my rusted OEM rotors and stops perfectly. I went cheap and am happy, if you don't want to go cheap you can still do it for a ton less than Z06 package. Powder coating is only about $250 for all 4 calipers.
Old Oct 24, 2013 | 12:14 PM
awacsdavid's Avatar
awacsdavid
I found a full set of operational Z06 calipers, pins and drilled rotors for $900. All i need will be pads.
Getting the existing calipers powder coated and getting new rotors, will cost close to the same. So why not go ahead and upgrade calipers??
Old Oct 24, 2013 | 12:15 PM
Carbotech Adam
Supporting Vendor
The 1521 pad in a 1 piece design is $509 total front and rear.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Old Oct 24, 2013 | 12:17 PM
awacsdavid's Avatar
awacsdavid
Old Oct 24, 2013 | 01:40 PM
FrankenPC's Avatar
FrankenPC
What thickness of spacer would we need to replace our stock brakes with Z06 using stock rims?
Old Oct 24, 2013 | 03:05 PM
TJay74's Avatar
TJay74
5mm spacer will work, BUT you will also need the stock Gumby wheel and the extend-o-lug nuts as well unless you are willing to put longer studs on the car. The Gumby wheel is the only stock one that the Z06 caliper will fit behind on a regular C6.
To Brake upgrade
Old Oct 24, 2013 | 03:06 PM
NY3quartrs5-oh
Powdercoated calipers $250, brakemotive rotors and ceramic pads $208, total $458
Z06 stuff you say $900, carbotech pads $509 Total $1409
BIG DIFFERENCE
Even if you don't go carbotech, hawk pads are around $200 so total would still be $1100 compared to $458....
Old Oct 24, 2013 | 04:00 PM
TerryL's Avatar
TerryL
St. Jude Donor '17
"Powdercoated rotors $250,"
You mean calipers right?
Old Oct 24, 2013 | 04:08 PM
NY3quartrs5-oh
yes, my bad, was writing fast
