Coolant/ engine temp.sensor
Old Oct 29, 2013 | 06:58 PM
Cherokee Nation's Avatar
Cherokee Nation
Default Coolant/ engine temp.sensor
Where is the sensor that monitors the coolant /engine temperature located at on a LS3? For the past week when i take my short ride at speeds of 40-45 MPH my coolant temp will go from 189 to 198 then back down then back up Coolant level is fine.What else could it be??....
Old Oct 29, 2013 | 07:20 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Could be air trapped in the system.
Old Oct 29, 2013 | 07:33 PM
Cherokee Nation
That was my other thought..How do you get the air out of these closed systems?..Thanks
Old Oct 29, 2013 | 09:35 PM
erick_e's Avatar
erick_e
Per the Service manual.
With the cap removed, start the engine and allow to the engine to idle.
Allow the engine to idle for approximately 4 minutes.
Slowly fill the coolant mixture until the level stabilizes at the base of the surge tank fill neck.
Run the engine between 2,000-2,500 RPM for approximately 2 minutes.
Allow engine to idle and add approximately 1 liter (1.1 quarts) of coolant to the surge tank.
Install the coolant pressure cap.
Shut the engine OFF.
Allow the engine to cool.
What I usually do is remove the overflow hose from the raditor allowing a passage for air to escape while filling the coolant reservoir.
Old Oct 29, 2013 | 09:53 PM
Cherokee Nation
Thanks erick..I see you are in Clarksville Tn.My better half was from there.I was there in 2007 for her Memorial,she has about 6 brothers & sisters there..
Old Oct 30, 2013 | 01:14 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Usually, a thermostat just sticks at some point. But I've had them do a few other goofy things, so that could be worth thinking about.
Best of luck...
Old Oct 30, 2013 | 03:15 PM
truckplay's Avatar
truckplay
the sensor is on the driver side head, under the exhaust manifold towards the front.
Old Oct 30, 2013 | 06:50 PM
Cherokee Nation
Best of luck...
The shop put in a new Mr Gasket 180 2 yrs ago,so I'm leaning to put in a new one because it is acting in town & we have been in the same weather frame for awhile..mid to high 80's....Thanks Guys for your inputs
Cherokee Nation
To Coolant/ engine temp.sensor
