Engine Bay Light
Old Nov 10, 2013 | 01:53 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default Engine Bay Light
My 2008 Z51 did not come with a light under the hood. Is there a part number for this and is it just plug & play?
Old Nov 10, 2013 | 02:00 PM
NY3quartrs5-oh's Avatar
NY3quartrs5-oh
yes, it's plug and play, BUT if yours didn't come with one then theres no hole in the liner. I think you can cut it though. I guess you'll have to rivet it in.... I think i remember it costing $35, i'll try to find it.
The plug where it plugs into is under the hood on the passenger side in front of the radiator shroud.
PART NUMBER: 19165567
Old Nov 10, 2013 | 02:05 PM
NY3quartrs5-oh
heres good info http://forums.corvetteforum.com/c6-c...ood-light.html
Old Nov 10, 2013 | 02:31 PM
ls1121's Avatar
ls1121
Great info thanx.
Old Nov 10, 2013 | 02:43 PM
Garibaldi's Avatar
Garibaldi
It's plug 'n' play if you have a pop rivet gun. I think you'll find they're more like $45-$50 now.
Old Nov 10, 2013 | 07:44 PM
z06clif's Avatar
z06clif
2006 was the last year for this. I have one in my engine bay. But before you go crazy let me say it is totally useless.
Clif
Old Nov 10, 2013 | 10:06 PM
AYello1's Avatar
AYello1
Also has caused dead batteries when they don't turn off.
Old Nov 10, 2013 | 10:22 PM
saplumr's Avatar
saplumr
Clif
No doubt. I pulled the bulb in mine.
Old Nov 11, 2013 | 12:02 AM
4thC4at60's Avatar
4thC4at60
Clif
2007
Old Nov 11, 2013 | 12:14 AM
ls1121's Avatar
ls1121
Clif
Ya might be right Thanx, no light for me.
Old Nov 11, 2013 | 05:52 AM
mittens's Avatar
mittens
My 06 had one, and it was always a pain when working ont he car to remove the bulb (burn your finger and blind you for a few).
Old Nov 11, 2013 | 12:42 PM
saplumr's Avatar
saplumr
I used a glove. The bulb gets hot instantly!
Old Nov 11, 2013 | 01:05 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I have a fairly early '07 and it does not have one. Also if you should decide to install one, you will need a new hood insulator blanket. They are formed to cover the light housing so you only see the lens. If you stick to your stock blanket and cut it, it will not look good.
Old Nov 11, 2013 | 01:44 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I have some underhood light harneses left if you need one, About 20 bucks shipped. You can find the light housing ion eBay for around 25 - 35 bucks.
Old Nov 11, 2013 | 02:27 PM
4thC4at60's Avatar
4thC4at60
My '07 does. Bought September '06.
Old Nov 11, 2013 | 02:34 PM
4thC4at60's Avatar
4thC4at60
Old Nov 11, 2013 | 04:38 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Clif
Our 2006 had the light, our 2009 does not.
On the '06, the light was bright enough to tell, barely, that the engine was still installed.
To Engine Bay Light
Old Nov 11, 2013 | 04:48 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
My 07 (Oct 06) did not have one. I used two small self tapping sheet metal screws and blue Loctite. Once the blanket goes up the only thing showing is the top of the light housing.
Old Nov 11, 2013 | 05:01 PM
saplumr's Avatar
saplumr
Yeah, it's one of those useless things. Now....a light in the glove box of GM vehicles would definitely be useful!
Old Nov 11, 2013 | 05:13 PM
Gearhead Jim
St. Jude Donor '13
Interesting, our 2009 has a glove box light but can't recall about the 2006.
No light in the 2009 console, I tried a small battery powered one stuck inside the lid but stuff in the console kept turning it on and killing the batteries.
Another
