Gas cap code
Old Nov 18, 2013 | 04:05 PM
tmd937's Avatar
tmd937
Default Gas cap code
My 2013 GS rolled over to 1300 miles today . Had not driven it in a couple of weeks . About a mile down the road a check gas cap code popped up. . I stopped the car and retightened the cap and reset . About 4 miles later it went off again . I took the cap off again and reset, drove another 5 miles and so far so good . Just wondering if anyone had any ideas as to why it would come on ?
Old Nov 18, 2013 | 04:07 PM
IndyPacer's Avatar
IndyPacer
Loose cap
Old Nov 18, 2013 | 04:48 PM
tmd937's Avatar
tmd937
I tried tightening it twice . Dealer said if it continued they would do a smoke test .
Old Nov 18, 2013 | 05:52 PM
mophead's Avatar
mophead
Somehow smoke, gas cap, and gas tank just ain't right.
Old Nov 18, 2013 | 06:11 PM
owc6's Avatar
owc6
OEM caps are crap. I had a little more success by doing this: Don't push on the cap when you tighten it. Once you get it threaded, pull slightly on it when you tighten it. It can take overnight or a few start cycles to get rid of the message or the the check engine light even after you actually get the cap tight.
OR, buy a Stant gas cap. ~$19 at the local auto parts store, and problem solved.
lisa
Old Nov 18, 2013 | 06:26 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Try this...
Take off the cap. Place it loosely on the pipe and DO NOT PRESS to help tighten it just turn lightly with your finger tips until it clicks 3 or 4 times. Pushing in to help it "seat" is a no-no.
Elmer
Old Nov 18, 2013 | 07:14 PM
Don-Vette's Avatar
Don-Vette
Originally Posted by eboggs_jkvl
Try this...
Elmer
Old Nov 18, 2013 | 09:38 PM
jwf's Avatar
jwf
Ditto.... Do not press to tighten.
Old Nov 19, 2013 | 01:16 AM
CO Lightfoot's Avatar
CO Lightfoot
Before doing anything else, I'd want to know if it's thrown any codes.
The problem might be more involved than just a gas cap:
http://forums.corvetteforum.com/c6-c...49-w-pics.html
It's easy to check for codes... I believe you can borrow a code reader from Autozone.
But you're under warranty. So if it needs the fix described in the above link, I'd let the dealer do it.
To Gas cap code
