Any vendor making a key fob with no buttons? Since everything works as I walk up to my car, I really don't need those buttons which pop my hatch or worse, set off my alarm because it bumped some coin in my pocket.
Some people disassemble the fob to change the battery, then put a thin piece of tape or paper under some or all of the button contacts.
Because I use the buttons occasionally, I bought a "Fob Jacket" (Google it). Cut a thin but stiff piece of plastic that slips under the jacket and covers the entire front of the fob, protecting the buttons. Then remove it to punch a 1/8" hole over each button and reinstall, so you can activate the buttons with a ball point pen.
Now, my alarm only goes off accidentally a couple of times per year, instead of a couple of times per day.
I like the idea of a small fob (the size of a key) with no buttons.
