OE Parts to upgrade your base C6 to the larger rotors of the Z51
This kit includes all 4 caliper mounting brackets, and all 4 Z51 rotors. You will use your existing caliper and pads. Rotors are zinc coated to prevent rusting.
Z51 Front and Rear Brake Kit
2 89060328 Front Rotors
2 89060329 Rear Rotors
2 88964166 Front Caliper Brackets
2 88964167 Rear Caliper Brackets
All you need are a set of Z51 sized rotors and Z51 brackets. I would not recommend drilled rotors however. DBA makes some great rotors. For brackets, check out the BST forum. Usually a set there. I think there is a forum member that even will provide the brackets freshly powder coated and take your base brackets as a core.
