Overheating Problem
While you are at it, change to a lower temp tstat. You will PROBABLY,(I HOPE), solve your problem and your car will run cooler.
Theres a company that makes a tstat for all cars EXCEPT corvettes. Its a "fail safe", if it fails, it fails open not closed as our conventional tstats do.
I am pretty sure LS3's are no diff than LS1's in that respect, tstats fail closed. I called that company years ago when I was driving C5's,(2000-2004), they said currently, then, their tstat did not work on corvettes, I don't understand why ?
Maybe somebody can correct me, if I am wrong about whether that company now makes a tstat for vettes or whether LS3's fail open, this is an issue I am anxious to find out about.
Either way, a "fail safe" thermostat sure makes a lot of sense to me. Why design a product that when it fails, it destroys a $14,000 engine ?
I was in the fire protection business, engineered Halon systems for data centers, all our devices "failed safe". We didn't count on a/c power to close a door, when there was a fire detected, the power was dropped from the device and the door closed, so no matter what, power or not, the door closed.
Why not do it with thermostats ? Seems simple doesn't it ? Maybe I should have been in the tstat business.
Last edited by Steve-O; Dec 16, 2013 at 03:30 AM. Reason: my personal experience in fail safe devices.
i think the suggest that the fan is wonky is a good place to look. You can get a switch inside the car that lets you turn on the fans when you want. If my car ran over 210 hot, I would add the switch.
Good luck.
Seems fairly common.....or one of the more common issues.
