High Speed Sway
'05 coupe, precision red, all stock, 51k miles, only repair was a new water pump at 48k miles. Hit a deep pot-hole, hard, left front wheel, then left wheel...I mean WHAM, BAM. When I got home, I jacked it up; could see no damage. Now, on the freeway, over 75 or so, my baby starts to sway, back and forth; at times so that it's hard to keep in lane. It's a rocking, swaying motion, but it's pronounced. Think it's, hopefully, just been knocked out of alignment? Any help and/or comments would be appreciated. Thanks.
St. Jude Donor '15
"In honor of jpee"
agree w. boomer. just remember that there are components underneath that could be bent, broken, or even pushed to replacement mode. that's beyond a good alignment. you have an '05 which is now potentially nine years old after it rolled out of the plant. things could be worn from age, if not miles or hard use. good luck and tell us if an alignment fixes everything.
Some auto policies cover pothole damage under the Comprehensive coverage. In addition, if you can document the location of the pothole, some municipalities will cover costs to repair your vehicle caused by road damage. Good luck!
Besides the alignment check the tire(s), wheel(s) and all the steering and suspension components....make sure they're not damaged or loose. A couple years ago I had a upper rear control arm bolt work its way loose. I suspected a problem getting up to speed on a straight-a-way....going into the first corner my suspicion was confirmed. Listen to your car....it's trying to tell you something. Good luck and let us know what you find.
