Help Help Help
Thanks.
BTW, the car will move forward very slowly while in gear even with the horrible grinding noise.
Something sounds gawdawful bad, what it could be is anyone's guess.
Strictly a dealer problem now, will be very curious to learn what they find so make sure to update.
Sorry to hear, good news is you're covered under warranty, ideally should be better than new.
Hopefully the Louisville market has two Chevrolet dealerships, might be time to give the other a shot. Sounds like the car's at Bachman now, will have to allow them to do the job since GM's paying, anyway.
Used to live in Evansville, had a good dealer there (Northside); but, we're talking some distance away from you -- assuming they're still in business after the 'reorganization'. Love to believe there's at least one competent dealer in a market the size of Louisville, KY.
In case you don't know Chevrolet assigns CSReps on the forum.
Find one & PM them your story. Make sure you've all the proper documentaion at the ready if asked, OK?
In the meantime wait hfor this matter to be resolved, hopefully to your satisfaction. Nothing (they've done) has happened, yet.
The axle shaft is one unit. The u-joint or as GM calls it the CV is probably bad.
When mine went it slung grease all over the underside of the car.
The axle shaft slides into the differential. The differential is attached to the Transmission.
Yes. The car needs to be parked for 24 hours according to the TSB.
I would ask them to place the old axle nut on after the new one to be used as a lock nut.
Thanks for setting the record straight, Harry.
The nincompoops didn't let mine sit 24hrs so despite having the upgraded nuts I suspect one or both are loose, again.
Oh well it's only Chevrolet's money they're wasting, because I will be back and they will fix it right.
Easter-egg troubleshooting and constant re-work gets expensive and eventually dangerous. If they are giving you one ounce of pushback, they would be looking for a new service manager or a new car.
I don't want to sound like an alarmist but I personally would have come unhinged. Then again, this is why I prefer to do as much work as possible on my bikes and cars, understanding this is quite different in that it is MAJOR work covered by waranty.
/r
Allen
Adding axle nuts to end links (which do NOT remain tight), a normal person would've assumed a solution found by now. Nope. Nevermind poor Harmonic Balancers & lousy valve guides. Freaking axle nuts.
I regret not being more specific in stating my issue's a warranty item.
Saftety notwithstanding if this malarkey was on my dime, they'd have got a what-for long ago. My Z06 is garaged for WI's Winter, on 'life support'. Safety, for now, is a moot issue.
#07-04-95-001A
and
#08-04-20-003
Write the TSB#s down, give them to your SA & ask s/he reads 'em.
