Headers and Dyno ?
Old Jan 22, 2014 | 08:29 AM
Dewayne'sZ06's Avatar
Dewayne'sZ06
Default Headers and Dyno ?
Last month I added a Vararam CAI and had a tune done. My base reading was 370RWHP and after the install and tune I had 400 RWHP. Yesterday i had Kooks 1 3/4" headers and x-pipe installed and freshened the tune up and only came out with 410 RWHP. I did pick up 20 lb's torque with the add but was really hoping for more HP. Is this typical gains for a car that has already been tuned? BTW My car is a LS3 A6 . Car Does sound Awesome at WOt though
Old Jan 22, 2014 | 08:39 AM
MBB's Avatar
MBB
A better comparison would have been to run it at the track before and after... I'd have thought that 430whp would have been around what you should be showing though. You have cats? What exhaust? If stock exhaust do you have NPP or no? You should get a set of bullets if you don't have an exhaust yet. It'll really sound good then.
Old Jan 22, 2014 | 09:37 AM
Dewayne'sZ06
I have the kooks high flow catted pipe and I do have the NPP exhaust and it was in the open position when dyno was run. I have never tracked the car so that comparison is out.
Old Jan 22, 2014 | 09:40 AM
MBB's Avatar
MBB
I see, well, don't get hung up on dyno numbers bro. The dyno is just a tool.
Old Jan 22, 2014 | 10:46 AM
irok's Avatar
irok
Default bang on
seems exactly right.what did it make for rw torque?
Old Jan 22, 2014 | 01:06 PM
Dewayne'sZ06
Torque jumped from 386.78 to 403.92
Old Jan 22, 2014 | 05:45 PM
PRE-Z06's Avatar
PRE-Z06
Just to make sure you're comparing apples to apples both runs were corrected right? Most with headers and a tune pick up ~30rwhp depending on primary size, so your gains sound about right with the smaller primaries. Larger ones would have made more hp with a trade off of torque which I wouldn't do with an auto personally unless chasing a dyno number.
Old Jan 22, 2014 | 06:51 PM
haljensen's Avatar
haljensen
If the temperature, barometric pressure and humidity weren't the same the dyno wont be accurate.
The Dyno compensates for them all but it can't compensate for the cars computer pulling timing and/or richer/leaner fuel trims due to air temps, MAP & MAF readings and coolant temps.
Old Jan 22, 2014 | 10:15 PM
Dewayne'sZ06
Im not sure if they were corrected or not but i would think they were..Both times the car was on the same dyno ...so i trust the numbers..was just trying to figure out why it didn't pick up the HP the headers claim to give. Temps were comparable both times it was run..nothing drastic between the 2 days
Old Jan 23, 2014 | 09:39 AM
haljensen's Avatar
haljensen
Your original 370HP sounds right but the 400HP w/Vararam and tune is high.
Your 410HP W/Headers/Tune/Vararam is about right. I would question the 29.17" barometer vs the 30.03 barometer of the earlier run. The Dyno that is wrong is the 400HP in between.
Remember that the Vararam results won't show on a Dyno since the hood is open for all dynos and you can't get a fan to duplicate actual airflow.
Old Jan 23, 2014 | 11:30 PM
berk4422's Avatar
berk4422
I also had a dyno at RPM and it seemed low. 358hp/366tq on an LS2 A6 vert w/ PTB, PIM, Kooks 1 3/4 +Xpipe, Borla Exhaust + mail order tune. But I'm running 12.3 @ 116. with 1.98 60's from an idle... I think the RPM Dyno is low. Let's test and tune at Fayettville MSP when it warns up... I bet you're in the 11's
Edit - and that was on bald run flats...
Old Jan 24, 2014 | 07:18 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Old Jan 24, 2014 | 07:20 AM
traderfjp's Avatar
traderfjp
What does your butt tell ya,
Old Jan 24, 2014 | 07:21 AM
Ryan T 997's Avatar
Ryan T 997
The dyno is just a tool as said above... My 08 ls3 m6 with 1 7/8 OBX headers, NPP mufflers , & vararam just made 423 rwhp 417 rwtq with a 15% load on the dyno .
To Headers and Dyno ?
