Battery removal
Dan
05 Z51 coupe
As for pulling the battery for long term, better off with a Battery tender when it sits in storage/any length of time instead.
When you reinstall the battery, you will need to re-index the windows, and if luck is not on your side, bank that you will have to reprogram the Fobs, TPMS's and maybe even the radio and control settings as well.
As for your current battery, if it went dead and froze, consider it dead (plates pushed together to kill at least a cell or two).
As for batter tenders, you can pick up a Ctek for around $50, and the way to go. What the Ctek does that other cheaper tenders do not, is it go into a Desulfator cycle after the battery has been fully charged to try to clean the plates (get more life out of the battery).
Note, again, if the battery has been frozen, then the plates have been wedged together and there is not saving this since the plates are now touching each other.
Trickle chargers can and will overcharge your battery in a few days.
There are several battery tenders on the market. just make sure it is an automatic cutoff type.
LJ
No problem taking the battery home and putting it on charge. Or if the battery is more than 3 or 4 years old you may just want to replace it.
When you put the battery back in you will notice that the window indexing is gone. Its simple to re-index, just put the window up and hold the button for 4 seconds on both windows. All other items like radio etc. have flash memory and will be no problem. When you take the battery out lower the windows about 2 inches first.
If your car is due for state inspection within the next couple of days, it will take about 50 miles or more of driving for the car to be in an inspection"ready" state.
