Rear diff not locking
Old Feb 15, 2014 | 06:27 PM
blackbird345's Avatar
blackbird345
Default Rear diff not locking
I have an 07 z51 6sp. I've always had an issue with the rear diff not locking so sometimes the two wheels spin seperate under WOT. Is this common? How can I fix?
Old Feb 15, 2014 | 06:31 PM
timd38's Avatar
timd38
Have you changed the lube? If you use Red Line don't use the friction modifier unless you get chatter. If that doesn't fix it, the clutches may have an issue.
Old Feb 15, 2014 | 11:36 PM
blackbird345
Ok cool I'll try that. I've never changed the fluid and it has 47k miles....
Old Feb 16, 2014 | 01:48 PM
timd38's Avatar
timd38
I have a lift and an oil drain tank in my garage if you want to come over.
Old Feb 17, 2014 | 11:44 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
IIRC, there is a specified torque required to rotate one wheel while the other is blocked in place, with the car on a lift. If it takes less than specified to rotate the free wheel, then something is wrong. Might need only a fluid change, or clutch packs could be worn.
Unfortunately, I can't verify either the concept or the numbers, and don't have my Service Manual with me today.
Old Feb 17, 2014 | 12:40 PM
theblue's Avatar
theblue
these cars have a limited slip, not a locking differential. odds are absolutely nothing is wrong.
To Rear diff not locking
